what is this disconnected wire under my hood? - JeepForum.com
post #1 of 28 Old 07-24-2008, 10:15 PM Thread Starter
MEinSoCal
look up, right in the middle of the hood insulation...
MEinSoCal is offline
post #2 of 28 Old 07-24-2008, 10:22 PM
spife7980
i think that is where the light is. when you lift it up so you can see in the dark or something but it sucks royally. at least mine does.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #3 of 28 Old 07-24-2008, 10:24 PM
GibsJeep
Your hood lamp no longer exists.
GibsJeep is offline
post #4 of 28 Old 07-24-2008, 10:34 PM Thread Starter
MEinSoCal
thats what happens when you buy a used jeep. you discover all these missing/disconnected parts
post #5 of 28 Old 07-24-2008, 10:41 PM
Windowsrookie
Light goes there, the connection had basically disintegrated on my old ZJ. I tried to figure out why it wasn't turning on, pulled the connection apart and a clump of corroded metal fell to the ground.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #6 of 28 Old 07-24-2008, 11:20 PM
Mr. Breeze
X5 on the light. Probably was disconnected if the switch got screwed up like mine, which doesn't shut off when the hood is closed.
'97 ZJ, 4wd, 4.0, 3" Pro Comp lift, 31" BFG MT KM2s, JKS Front & Rear trackbars, JKS Disco's, Rear Aussie
Mr. Breeze is offline
post #7 of 28 Old 07-25-2008, 02:24 AM
kentman
kentman's Avatar
2006 XK Commander
I did not even get one of those in the WJ. Chrysler was looking to shave a few dollars off of the WJ I guess. When doing any real work, you have to bring in a real light anyway. It is nice at night to have a little light just to check something quickly.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #8 of 28 Old 07-25-2008, 03:43 AM
cockney
The light works via an inbuilt mercury switch and they do cause flat battery problems by not turning off. john.n
cockney is offline
post #9 of 28 Old 07-25-2008, 03:49 AM
funpig
Yeah. I killed a few batteries (luckily replaced under warranty) until I noticed the darn light was still on when the hood was closed.
funpig is offline
post #10 of 28 Old 07-25-2008, 07:49 AM
Windowsrookie
Earlier models did, it was probably optional though. My WJ has every available option except for the 10 cd-changer.
1987 Wrangler 4.2L
post #11 of 28 Old 07-25-2008, 09:49 PM
kentman
kentman's Avatar
2006 XK Commander
I have the changer but no hood light. Mine did not come with a cargo cover or roof rack rails. I have since added the rails. I would not mind buying the cargo cover some day also.
kentman is offline
post #12 of 28 Old 07-25-2008, 11:13 PM
nashmd454
nashmd454's Avatar
x 15 on the light..........
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #13 of 28 Old 07-25-2008, 11:34 PM Thread Starter
MEinSoCal
i guess i won't be adding the light anytime soon.
post #14 of 28 Old 07-25-2008, 11:40 PM
moparrr07
mine looked exactly the same when i bought mine
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #15 of 28 Old 07-26-2008, 01:49 AM
cockney
Got to add that the light is as good as useless anyway. Anyone thinking of adding 1 would be better of buying a flashlight and keeping it in the glove box! john.n
cockney is offline
Can I Drive with CCV Disconnected? CrazyIvan888 ZJ Grand Cherokee Forum 4 11-05-2009 09:43 PM
2003 Hood Struts Bad! Hood falls on my head..... 86Spider ZJ Grand Cherokee Forum 16 08-20-2008 12:16 PM
Engine harness wire to coil pack wire is frayed dustindu4 ZJ Grand Cherokee Forum 1 06-26-2008 01:18 PM
Disconnected stock WJ? SeanSR ZJ Grand Cherokee Forum 41 06-14-2007 11:25 AM
Disconnected ZJ's AWILD ZJ Grand Cherokee Forum 15 09-14-2005 01:23 PM
