what differentials does my 93 grand cherokee have? - JeepForum.com
post #1 of 5 Old 01-28-2014, 04:38 PM Thread Starter
93zj317
I have a 93 grand cherokee laredo with the 4.0 an command trac, assuming its command trac since it only has 2wd, 4wd part time,n, and 4 low, the guy i bought it from said it has limited slip front an rear diffs but how do i tell ?
93zj317 is offline
post #2 of 5 Old 01-28-2014, 04:47 PM
WhiteOut
WhiteOut's Avatar
Dana 30 front, Dana 35 rear/ Most likely 3.55 gears, the rear will have a tag showing if it has LSD or not.
WhiteOut is offline
post #3 of 5 Old 01-28-2014, 04:55 PM Thread Starter
93zj317
Ok were would the tag be located i looked an couldn find nothing an if the rear has ls. Will the front have limited slip?
93zj317 is offline
post #4 of 5 Old 01-28-2014, 04:56 PM Thread Starter
93zj317
And am i right on the command trac since it only has 2wd, 4wd part time an 4 low?
93zj317 is offline
post #5 of 5 Old 01-28-2014, 05:19 PM
WhiteOut
WhiteOut's Avatar
No limited slip in the front. You have the NP231 Command Trac
WhiteOut is offline
