What a difference a full tune up makes (WJ) - JeepForum.com
post #1 of 17 Old 12-07-2006, 12:30 AM Thread Starter
RobertTF
RobertTF's Avatar
I decided to take it upon myself to do a full service on my WJ instead of paying ridiculous amounts of money to take it to the dealer. Here is a list of everything I did and then my conclusions.
- Bosch Platinum Spark Plugs: 4230 (The old Champion Coppers had eroded to a gap of .047 compared to the stock .04)
- Valvoline Max Life 10w-30
- Purolator PureONE oil filter
- Royal Purple 75w-140 Synthetic in the Diffs (plus half a bottle of FM in each)
- Valvoline ATF+4 Synthetic Transmission Fluid (changed the two filters as well)
- Mopar Transfer Case Fluid
- Bored out the throttle body and cleaned it (Removed it, used the dremel to bore it out a bit, polished it up, ground down the protruding screws on the butterfly, filed down the tab sticking down at the 12 o'clock position on the intake manifold, and cleaned it up nice and good)
- Bled the brakes
- Greased up the disconnects and addco bushings
After first turning the engine over, I noticed immediately that the idle was much smoother and it seemed to be running a lot better. I decided to take it for a drive around town and on the highway. Brakes were a lot more responsive (I think I had some air in the lines), engine was much more responsive and acceleration was smoother, and last but not least, MPG went up dramatically! I went from an average of 14.5mpg to 17.1mpg! I drove for about 45 minutes (15 around town and 30 on the freeway). The freeway was half 63mph and half 73mph. I think everything is running a lot more efficiently and the old plugs aren't burning excessive fuel anymore. I'd have to say that this is one of the best things that I have done yet to get it running better. I think I spend maybe $200 total in parts and fluids.
2001 4.7l Limited WJ
IRO 6.5" Critical LA, Lonestar Incline Bumper, XRC-8000 Comp Winch, 33" BFG All-Terrains, and a long list of other stuff.
RobertTF is offline
post #2 of 17 Old 12-07-2006, 02:00 AM
10achik
I ate what?
10achik's Avatar
It's nice to show some love to the Dub. I usually keep mine regularly maintained, but do the main tune-ups in the late spring, I hate working on it when it's 20* or 100*. Since I can't get it in the garage anymore, I'm at the mercy of the weather. I've got a new clunk to check out now, but I aint working on it in the driveway right now that's for sure, it's about 18* and about 2" of solid ice out there...suck
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 17 Old 12-07-2006, 03:21 AM Thread Starter
RobertTF
RobertTF's Avatar
I always change the oil every 3,500 - 4,000 miles and had a big service maybe 15k miles ago. Just decided that I would go to synthetics besides motor oil. When you treat the dub jay right it shows you the love in return. How is the 5.5" IRO lift working out for ya? How do those 32's look under it? I am probably going to end up with the 5.5" IRO LA setup when it comes out. I'm trying to determine whether I am going to get the 32 or 33" Bighorns. How are they working on the ice and snow for you? We just finished up with our snow storm and its almost all gone. Probably the only snow we will see all season. 15" of snow in one night. I think that has to be some record for us.
RobertTF is offline
post #4 of 17 Old 12-07-2006, 08:10 AM
RBall151
What is FM? I'm drawing a blank..
2001 WJ I6 Steel Blue Pearl Coat | 2" BB : MX-6 Shocks : 245/75/16 Bridgestone Dueler AT's
Silverstars : K&N FIPK2 : 42RE : Dana 35C : 3.73 Ratio
Cliff Designs 3.2LX : Fosgate 12" HX2 | Infinity Reference 3012cf 3.5" Dash Speakers
RBall151 is offline
post #5 of 17 Old 12-07-2006, 08:13 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I am doing plugs in the spring fosho... I am sure the dub needs it. She does run smooth as of now though.
Sence I use ful syn motor oil I am pumped I don't have to change the oil all winter!!!
2013 FR-S
BlaineWasHere is offline
post #6 of 17 Old 12-07-2006, 09:32 AM
hinchcliffe
hinchcliffe's Avatar
It's nice to give the dub some love instead fixing something wrong with it. Plugs and maybe tires come spring. Everything else should be upto snuff. NIce.
'06 XK Inferno Red Crystal Pearl/Gray Leather
hinchcliffe is offline
post #7 of 17 Old 12-07-2006, 09:34 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
FM = friction modifier
Wheelin98TJ is offline
post #8 of 17 Old 12-07-2006, 12:27 PM
Arkansas_WJ
Arkansas_WJ's Avatar
quadra drive only mind you
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #9 of 17 Old 12-07-2006, 02:31 PM
aggiejeep
the vari-lok(c?) requires the FM also
aggiejeep is offline
post #10 of 17 Old 12-07-2006, 02:51 PM
mendelmax
vari-lok is a part of quadra-drive
Anyway, yeah, good oil=good MPG, tested myself
I'm also thinking about boring TB, but I have one doubt about it- is it hard to adjust all the linkage after installing it back to its place? Because this is the thing I'm afraid most :/
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #11 of 17 Old 12-07-2006, 03:04 PM
///BHRpowered
///BHRpowered's Avatar
no vari-loc is the quadra-drive, but I believe the trac-loc quadra-trac2 systems highly recommend it.
The only thing I haven't done on my Wj yet is the tranny flush and diffs, hopefully doing the diffs this weekend
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #12 of 17 Old 12-07-2006, 03:12 PM
Wheelin98TJ
JEEP FREAK
Originally Posted by ///BHRpowered
no vari-loc is the quadra-drive, but I believe the trac-loc quadra-trac2 systems highly recommend it...
If you have a Trac Lok diff, you definitely need the friction modifier.
Its not just the QuadraDrive WJs that need the FM.
post #13 of 17 Old 12-07-2006, 03:13 PM
10achik
I ate what?
10achik's Avatar
How is the 5.5" IRO lift working out for ya? How do those 32's look under it? How are they working on the ice and snow for you?
Man I love this kit, it's been great, although I've got a new clunk I'm trying to figure out at the moment but it's to cold to work on it. The 32's look fine but I'm definately going to 33's as soon as these are worn out or sooner if I get some extra cash. These Bighorns are absolutely the best tires I've ever run in every condition.
I'll go ahead and let the cat out of the bag here since a few people know already, but I've been working on a deal with IRO to test and run their 5.5" Long Arm setup. I'm only going to run the front for now, but will eventually run the back as well. They have been testing it on their Shop WJ and made me a deal to run it on mine, so hopefully soon I can get it and get started on it.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #14 of 17 Old 12-07-2006, 03:27 PM
Arkansas_WJ
WJ's came with trac lock?
i thought just vari
Mitch
post #15 of 17 Old 12-07-2006, 03:33 PM
mendelmax
Nope, trac-lok was also available, but rather rare- if someone wanted traction he just bought quadra-drive. If he didn't- why bother with any LSD then
Part time and Full Time 4WD Difference Igorot_Jeeper ZJ Grand Cherokee Forum 12 06-09-2017 06:43 PM
4.0L run bad after full tune up. NeverL8 ZJ Grand Cherokee Forum 5 01-24-2010 03:11 AM
Full tune-up HELP BHand89 ZJ Grand Cherokee Forum 11 11-05-2009 10:32 AM
Wife's ZJ has had full tune-up / overhaul, still throws code 43 Crit ZJ Grand Cherokee Forum 6 08-31-2009 12:08 AM
GC Part-Time and Full-Time 4x4? What's the difference? rockon1202 ZJ Grand Cherokee Forum 14 03-04-2005 03:19 PM
