08-08-2010, 10:23 PM
#1
Consider the following...
What did you do to your ZJ today?
This thread is to serve as an inspiration to others modifying their ZJ's. Pretty simple, just post what you did to your ZJ today!
Today I shamefully took my Jeep to get the oil changed because it was to hot to change it myself.
Put your bacon where your mouth is!
08-09-2010, 01:33 AM
#2
first post, huh. being nocturnal pays off. I finally admitted that i screwed up on the re-installation of my oil pan after replacing the rear main. it was leaking oil worse than before so i took it back off(not the easiest effing thing to do on a stock height ZJ) and re-re-installed it so now it dont leak. all of this done from 11:30-1:45 AM, in the dark with the aid of a large fluorescent light
Oh yea and i foiled an attempt for some guys trying to egg my jeep( i had just finished and heard talking) they were some high school kids trying to end the summer with some egging fun. not on my block lol
TJ-
[SIZE="1"][B]95 ZJ 5.2[/B]- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.[/SIZE]
[QUOTE=slayercr23;12630497]How would i go about Stroking it?[/QUOTE]
08-09-2010, 01:37 AM
#3
zj tractor
did more research...
still dont know what route to go with for upgrading my power steering pump.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread: http://www.jeepforum.com/forum/f197/...ndard-1056365/
08-09-2010, 05:19 AM
#4
hmm. i got up and washed the eggs off my jeep. little bastards came back i guess
TJ-
08-09-2010, 05:23 AM
#5
O
Changed the front diff oil out, ordered some currie lower ca brackets since i ripped one of mine off the other weekend...
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
08-09-2010, 07:34 AM
#6
Ordered another set of gaskets and bolts for my intake manifold, as the rear seal strip didn't stay seated right after I did the plenum and now I have an oil leak.
08-09-2010, 09:56 AM
#7
I bought new rear brakes to add to the pile of parts waiting to be installed. I also bought a new garage furnace to keep her warm this winter
08-09-2010, 11:51 AM
#8
5.9,242,4.56,Aussies x 2
I Bought some Cool Hella or Hella Cool 500 ff lights to replace my bused OEM lower driving lights. Time for some more night wheeling trips. anyone? Also, greased my zirk fitting on my JKS quicker disconnects and all 4 of my new Flex control arm Joints. Almost no Rough Country left to my Lift now, that's a good thing!
Military Jeepers.Com.
Jeep Forum member since 2/2002
5Nine=No replacement for Displacement
08-09-2010, 12:41 PM
#9
Haha sadass, Hopewell Junction NY? My father lives up in Millerton. I'll need to swing by next time I come up there and you can show me where to go wheeling. I haven't been back to NY since I got the Jeep last summer.
08-09-2010, 12:45 PM
#10
today i took acetone to my cragar wheels and took off that blue and red stripe and i also cleaned up my hid wiring
ZJ Build thread:
[URL="http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/"]http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/[/URL]
ZJ's: If you dont know what it is you cant afford it.
08-09-2010, 01:34 PM
#11
Derp.
Threw the junkyard Bosch injectors on the test bench for a flow & actuation test, made up a matched set and did a quick refurbish on them. Hopefully will have time to swap them out with the Dekas this evening.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
Junkyard Jeeper
08-09-2010, 04:28 PM
#12
new rotors and pads on the front
08-09-2010, 04:52 PM
#13
Water pump leaked 2 weeks ago and blew out the rad cause it got too hot. Replaced water pump with a high flow from Summit. Replace the radiator with a all metal one from Radiator barn. Still was running warm and now replaced the fan clutch. Thermostat and radiator cap were also replaced. All new cooling components and she's running cool again!
08-09-2010, 05:09 PM
#14
put it through its paces
1998 ZJ 2" bb and 31's. street queen but sees the woods once in a while.
2000 powerjoke tow pig
Anti-jeep--1989 K5 blazer. the new off road ride
08-09-2010, 05:13 PM
#15
Towed out a stuck Bronco and fixed a leaking brake line!
-Nick
1995 ZJ Limited IRO 5.5" Critical Path Long Arms Armored and Aussie locked
