As awesome as those rims are (XJ / KJ Icon rims), I hate to break it to you, but they're 16x7, not 16x8. AFAIK, the only factory 16x8s Jeep had in 5x4.5 are TJ Moabs. TJ Canyons and Ravines were 15x8. Other than that, most of them were 7" wide rims (all ZJ stock rims included).
Hmmm, care to wager?
I had the tire shop pull off just the driver's front tire so we could mount one new wheel, set it down and check for clearance/rubbing issues before we busted down the remaining 3 tires. After breaking down the first snowflake (def 16x7), we layed it flat on the shop floor next to the icon so I could compare offset position. The icon was visably taller (by about an inch). The guy at the tire shop had never seen the icon style wheel before and I told him they were off a kj. To his credit, he knew what a kj was and liked them so much he wanted to put some on his jk. I told him he would not be able to because of 5x4.5 vs 5x5 lug spacing. He was bumbed.
We aired up the new icon and I noticed how it spread the sidewall out just a little on my 225/70/16 wild countrys compared to the snowflake. I asked him to do an inside balance because (A) Wheel weights on the outside of a wheel look like hell and (B) I did not want wheel weights to corrode the clearcoated lip on the new wheels. It is not as precise as a dual-plane balace but these tires are fairly small and in really good shape. They would not take much to dial in. I stood there as he loaded the wheel/tire combo on the balance machine. Measured the diameter first and then used the black sissor-style width gauge finding an 8 inch wide wheel beadlip to beadlip. I assure you, they are 16x8's.
I would not be supprised if the factory kj steel wheels were 16x7 but these, my friend, are 8's. I bought them quite a while back and have been sitting on them as I had not gotten around to preping and painting them to match body color on my 95. Well, that and I already had grizzlys mounted on 30x9.50x15 bfg ko's for the 95. If I did paint the icons, I would have to buy larger 16 inch tires or run the small 225/70/16's.
Thanks for the thumbs up on the style, though. I really like the way they look on the zj. I am tempted to get another set but having two jeeps with same wheels would be boring. I think I am going to mask and paint the grizzlys moss green to match my 95 (leaving the outer lip with the stock clearcoated aluminum look and that way I won't need a new set of tires right away.
