What did I do. - JeepForum.com
post #1 of 18 Old 04-07-2013, 09:43 PM Thread Starter
EOD-97-ZJ
I have a 5.9 and today I was trying to change the factory headunit out with a Kenwood that I had. Well see what happen was I couldn't figure out how to wire it in the short time I had so I spliced the original connectors back in and hooked the factory one back up. Well when I was done my key fob wouldn't work, my alarm went freakin nuts and the alarm would kill the Jeep. Well I found the purple and gold wire and shorted it so now it runs but my key fob won't work. And when I got home it would crank but not start so I had to reset the computer. Does anyone have any idea what stupid thing I did and how to fix it? And dome lights randomly come on.
97 4.0 ZJ All adjustable JKS CA's, TB's, and Disco's, Rancho Stabilizer, Full-Traction Springs.
98 5.9 ZJ soon to have above list.
EOD-97-ZJ is offline
post #2 of 18 Old 04-08-2013, 10:09 PM Thread Starter
EOD-97-ZJ
Well I bought a wiring harness and that didn't fix it but it did let the kenwood work. The guy at the audio shop said I screwed it up when I cut the purple wire and the white wire (the only connector with just two wires). So what can I do now
post #3 of 18 Old 04-08-2013, 10:46 PM
riot1987
Next time go to crutchfield and get the proper wiring harnesses. Ive had really good luck with their service and ease of install
Build thread^^
riot1987 is offline
post #4 of 18 Old 04-09-2013, 12:05 AM
zander21510
Yeah I got one of those adapters that plugs into the factory harness and ends with pre-spliced wires.
Anyways, sounds like a fuse is blown somewhere. Check that first.
zander21510 is offline
post #5 of 18 Old 04-09-2013, 10:54 AM Thread Starter
EOD-97-ZJ
I've checked fuse 3,5,7 and 16 is pulled (all from passenger floor board)
post #6 of 18 Old 04-09-2013, 10:56 AM Thread Starter
EOD-97-ZJ
Do you know what fuse it is?
post #7 of 18 Old 04-09-2013, 11:09 AM
zander21510
Check your under hood fuses. There is a black box next to the battery that holds relays and fuses. That's probably where it is if it is a fuse.
post #8 of 18 Old 04-09-2013, 11:15 AM Thread Starter
EOD-97-ZJ
Alright I'll check it out once I get home tonight
post #9 of 18 Old 04-09-2013, 04:00 PM
um7267
never cut factory wiring, just dont do it, resale value goes in the toilet the next owner will hate you and they will laugh at the wiring job.
and i agree check fuses
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #10 of 18 Old 04-09-2013, 04:15 PM Thread Starter
EOD-97-ZJ
I completely agree. I was trying to save a dollar. Well I finally got my hands on a 5.9. I don't plan on getting rid of it.
post #11 of 18 Old 04-09-2013, 04:39 PM
96zedjay
The Purple and the White wire on the 2 pin connector is the CCD/CAN bus, it's a data line...... If you cut and connected these to anything with power or ground you could have smoked: BCM,PCM,Dashboard,VIC, Door control modules, Alarm module... Could be a very expensive mistake.
96zedjay is offline
post #12 of 18 Old 04-10-2013, 06:13 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Hope he didn't let that wire just dangle or cut them when the battery was connected.
It does sound like he at least killed the door module and made the bcm very unhappy.
ratmonkey is offline
post #13 of 18 Old 04-14-2013, 11:55 AM Thread Starter
EOD-97-ZJ
Well no fuses are blown so im just gonna rock it with out keyless entry and call it good.
post #14 of 18 Old 04-18-2013, 07:07 PM Thread Starter
EOD-97-ZJ
Could original post cause a battery drain?
post #15 of 18 Old 04-19-2013, 06:52 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Yes, if you fried a module it could be a constant short.
