What are common issues with WJ - JeepForum.com
post #1 of 45 Old 10-22-2009, 11:11 AM Thread Starter
GreekGhost
Hi all -
I am in the process of selling my 2003 BMW (PM me if interested ) and looking to purchase a Grand Cherokee shortly after completing the sale.
I was curious to know what common issues do the WJ have and about what mileage do I need to be conserned about these things? For example, it is common for the BMW 3-Series (2000-2005) to need a cooling system overhaul at about 50,000 (which mine has had done). This is not part of regular maintenance but rather just an issue with the design. I am looking for these types of issues with the WJ's.
I was hoping to get one with about 60,000 miles but I am willing to go a bit higher if the price is right, depending on the issues.
Current: 2013 Jeep Wrangler Unlimited
Past: 2013 Jeep Grand Cherokee Laredo
1998 Jeep TJ SE
GreekGhost is offline
post #2 of 45 Old 10-22-2009, 11:18 AM
gbauer
Originally Posted by GreekGhost View Post
Hi all -
Oh god. Not another BMW owner here about a Jeep....
My 1999 WJ, 4.7L has been great (200k miles). The only major issue was the transfer case but it was a cheap fix (swapped to a 242 case: better case with more options: 2wd for instance). Parts are FAR cheaper than BMW parts. By far, I mean by a TON! For instance: a BMW supercharger is $10k installed. Jeep: 3k. My fuel filters: BMW: $50, Jeep: $20.
Get it.
Are you in the local BMWCCA? If so, a lot of us also have Jeeps: Me (George), Bogden, Pete, etc, etc.
(I own a 1998 M roadster.)
gbauer is offline
post #3 of 45 Old 10-22-2009, 11:22 AM Thread Starter
GreekGhost
lol I assume there are a lot people that post about this? I am not in the BMWCCA, nor do I know really what that is. I have my Wrangler which I will probably be buried in but the BMW while it has been a beautiful car to drive, I have to get rid of it mainly because I need a vehicle with more utility use.
My exgirlfriend used to have a Grand Cherokee along with one of my room mates and they never said a bad thing about them. They are a blast to drive (IMO) and most of all it is Jeep. I will probably only own Jeeps for the rest of my driving life.
1998 Jeep TJ SE
post #4 of 45 Old 10-22-2009, 11:24 AM
gatorayde
^^ Where did you get a $20 fuel filter for your WJ? They are ~$80 from the dealer because they are not just a filter, but a regulator as well.
Basically, the newer the WJ the less problems. The 99-01's had crappy front calipers that like to warp rotors every 5k miles or so when they wear out. If you can, find a V8 with the selec trac T case. It's rare, but it's a very nice setup. Models with the auto climate have blend door issues and it's an expensive fix or you have pull the dash and do it yourself. There's probably more but those are the biggest things that come to mind.
gatorayde is offline
post #5 of 45 Old 10-22-2009, 11:25 AM
99avant
It is common for new owners, and those looking to purchase, to not use the search function.
:-) This gets asked weekly, if not daily here.
Cliffnotes- buy a v8. Limiteds have blend door issues($1k fix), 242HD transfer case FTW, window regulators and and lock actuators live short lives. Other than that it is pretty typical jeep stuff.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #6 of 45 Old 10-22-2009, 11:32 AM Thread Starter
GreekGhost
Yeah I figured I should use the search after I posted. Been a member for many moons (joined 2003). Pardon my annoyance. I was hoping to get an idea of mileage when certain parts fail. Your input is greatly appreciated however. My room mate has a 2002 or 2003 with the V8 and Quadra-Drive. He told me to avoid that since parts for that transfer case are more expensive. I am hoping to get a V8 but I will settle on the 6 cylinder.
1998 Jeep TJ SE
post #7 of 45 Old 10-22-2009, 11:35 AM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Common Issues as I see them:
- brakes on earlier models (warping rotors often. easy fix though, updated calipers and aftermarket rotors last much longer)
- electric cooling fan relays and electric fan motor brushes wearing out. (search this: also easy fix, just replace relay and fan motor and you'll be happy. I also recommend adding a mechanical fan if you don't have one, or avoiding these issues by finding a WJ with a hydraulic fan)
- Transmission leak: Eventually your transmission output seal will leak. Not too bad/expensive to replace.
- TRE's/balljoints <-- this is general for all used cars: I always find that owners never even touch balljoints or TRE's on their cars. I always replace these when I get a used car. It will make it that much better).
- Blend doors: On models with dual climate control/auto climate control, these buggers fail and require dashboard surgery to remove. (Parts cheap labor expensive)
- Some transfer cases are weak (I would target a WJ with the 242 otherwise known as selectrac)
So If I were you I would target a WJ with a 4.7L, Selectrac, and manual climate control. (but good luck finding that set up)
That being said my simple 4.0L laredo hasn't really let me down after all of the above upgrades.
WALTER
walter_da_jpr is offline
post #8 of 45 Old 10-22-2009, 11:39 AM
99avant
That is why you swap to the 242HD tcase. Like I did!
I am not annoyed, just saying that it is more efficient to search than to sit around waiting for us nerds to babble on. It will sound like a broken record when you read threads about this.
99avant is offline
post #9 of 45 Old 10-22-2009, 12:23 PM
gbauer
My bad: $30 at autozone. I had to recheck it online.
Next time you need to buy a fuel filter, send me the $80 and I'll send you two and buy myself some beer with the leftover monies!
gbauer is offline
post #10 of 45 Old 10-22-2009, 12:27 PM
gbauer
Like mine (now that I did the 242 swap).
The 242 swap isn't that hard if the milage is low. If you buy it and want to do the swap, PM me and bring it out to Fredneck. We can do it in less than a day assuming the drive shaft is the correct length. If not, I have a guy that can do the shaft very quickly.
gbauer is offline
post #11 of 45 Old 10-22-2009, 12:38 PM Thread Starter
GreekGhost
Awesome, I can bring beer!!! I am definitely going to be purchasing one. Just a matter of selling the BMW before I do so. I want to pay cash for it.
1998 Jeep TJ SE
post #12 of 45 Old 10-22-2009, 12:40 PM
leaf001
Power window motors/ regulators/ Replaced 3 of mine at almost $300 a pop.
leaf001 is offline
post #13 of 45 Old 10-22-2009, 12:55 PM
Double E
Double E's Avatar
Check my sig for mileage and what's been upgraded & fixed. Pretty much all of them have needed these things.
+1 on the V8 vote. You won't regret it ...even once. The I6, you'll regret about 3 times each month at some point.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #14 of 45 Old 10-22-2009, 12:58 PM
gbauer
Probably just bad electrical connectors. I think you might have wasted $900 there.
Every time mine died, it was just a dirty connection. The one exception was the passenger's side window actuator.
gbauer is offline
post #15 of 45 Old 10-22-2009, 12:59 PM
gbauer
Post it up on bimmerfest, bimmerforums and craigslist.
I'm always up for beer. Something other than Buttwiper, Coors, or Miller please.
gbauer is offline
Common 4.0 Issues? Kota04SXT ZJ Grand Cherokee Forum 28 06-30-2009 08:50 PM
Common issues w/ a 00-02 WJ??? Giff ZJ Grand Cherokee Forum 1 10-13-2008 03:22 AM
Common? P-StAcK ZJ Grand Cherokee Forum 15 11-21-2007 12:05 AM
Is this common? FritzTJ ZJ Grand Cherokee Forum 3 03-20-2007 12:48 PM
Common WJ Lift Issues JayIV ZJ Grand Cherokee Forum 44 09-02-2006 09:39 PM
