What Color Should I Paint My Cladding--Pics - JeepForum.com
post #1 of 32 Old 01-20-2010, 08:00 PM Thread Starter
grandcherokee12
Hey guys, I know I want to paint my bumpers and cladding, just not sure what color... Let me know what you guys think. Thanks in advance.
Also, if anyone can do some quick photoshop, I would appreciate it.
2" BB with Rough Country Hydro shocks, General Grabber 245/75-16, Flowmaster 40 series, new steering stabilizer, limited headlight cases with fogs behind the grill
grandcherokee12 is offline
post #2 of 32 Old 01-20-2010, 08:03 PM
EisBlade
EisBlade's Avatar
Black is beautiful. lol I had that nasty sun faded grey as well. I sanded, put paint adhesion on it, then spray painted mine with truck bed coating. That was two years ago and they still look fresh.
JT
Harley-Davidson Touring Bikes (60K members strong)
EisBlade is offline
post #3 of 32 Old 01-20-2010, 08:06 PM
Steve01WJ
2005 WK
i love the look of that bed liner on there! I think im going to do that on mine in the spring
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline
post #4 of 32 Old 01-20-2010, 08:11 PM Thread Starter
grandcherokee12
I do like the black on the red paint, just unsure about the contrast on my grey... do you think it will make it look cheap? Thanks again.
post #5 of 32 Old 01-20-2010, 08:12 PM
SnowLeopard
That's the best bed-liner job I've seen on cladding. You need to do a write-up on the specifics of what you did/used. Brands and everything.
SnowLeopard is offline
post #6 of 32 Old 01-20-2010, 08:33 PM
EisBlade
EisBlade's Avatar
I don't think it'd make it look cheap. In my opinion I think it would pull together the blacks you already have...side mirrors, window moulding, door handle, tires, trim, etc. You could grab my photo, crop the side panels, and paste them onto yours for a quick look.
Thank you. A lot of work and time with pieces hanging from my garage door channels. lol
I didn't take any pics during, only the finished product as shown in my gallery. I will say though - I did it the hard way, by removing every piece of cladding; bumpers, door panels, sides, etc. A PITA to remove and especially to put back on. I broke off some of those plastic tabs that hold the cladding on (and currently have the bottom edge of my driver door hanging free slightly) and had to buy some 3M double-sided tape just for moulding. If doing it again, I think I would use that roll-on type you see in Advance Auto or O'Reilly's.
I put a metal wire brush attachment on a variable drill and ran it over every piece to rough it up. I sanded areas I couldn't reach, and sanded areas where the wire bristles roughed it up too much. I then sprayed on bulldog plastic adhesive promotor, followed by many thin coats of spray on liner. The result was a durable textured finish that wasn't so rough that it catches and holds mud in little pockets everywhere. I use a plastic brush on it when washing the car. Because the front bumper gets sandblasted, rocks, etc as you cruise down the highway - use more layers. (most do, I'm a slow poke though and enjoy the ride - I'm never really up on someone's back end enough. This helps me avoid rearend collisions, ruining all the work to keep the WJ nice, and reduces wear on the headlight lenses)
If I had to redo it, I'd tape off everything and leave everything on except the bumpers. And I'd use that roll-on stuff you can buy in a can though I'm not entirely sold on the rollers provided. I've checked out the example they include with the kit and have found it to be a rougher surface than I'm looking for. I think a synthetic house roller with shorter loops would work best to create a nice smoother finish with some textured rippling.
Just grab a plastic storage bin or trash can from the garage. Sand it down, etc. and conduct a test with some spray liner to see what you think first.
/another pic from the rear... Notice how that driver panel isn't as tight against the body as it should be. My fault; it was the first piece I pulled off and I didn't know what I was up against. I suggest leaving them on and tape around instead.
JT
EisBlade is offline
post #7 of 32 Old 01-20-2010, 08:41 PM
perfectcircle
I had the same color WJ and painted the cladding black anyways. it looked goofy. i'll find pictures
edit:
Given this was like 5 minutes after I painted it. It did tone down quite a bit later down the road as seen here:
perfectcircle is offline
post #8 of 32 Old 01-20-2010, 08:56 PM
Steve01WJ
2005 WK
yea thats a bit glossy......maybe the bed liner wouldnt be so bad.....I did my grill and it blends well with my brown jeep
post #9 of 32 Old 01-20-2010, 08:56 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Look at lakamida (don't know how exactly to spell his name) build thread. His is taupe with black too.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #10 of 32 Old 01-20-2010, 08:57 PM
perfectcircle
lakailimited06?
post #11 of 32 Old 01-20-2010, 09:00 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Yes, that is it. Is yours green yet?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #12 of 32 Old 01-20-2010, 09:05 PM
perfectcircle
Olive drab the past few months. I got laid off right after I started sanding it down to get it painted So I spray painted it and I finally got a job today actually. I lost my place to spray so i don't know what i'm going to do. All the local shops want 3k to paint it.
post #13 of 32 Old 01-20-2010, 09:08 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Dam, that sucks. Glad you found a job though and good luck with painting.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #14 of 32 Old 01-20-2010, 09:14 PM
perfectcircle
Thanks! I went wheeling with some guy last summer that paints and has a shop. I need to find his card and get a quote. Worse comes to worse i'll conform and just get it sprayed a normal color like black or white for cheap.
post #15 of 32 Old 01-20-2010, 09:17 PM Thread Starter
grandcherokee12
Thanks for all the input... do you think I could find the OEM same color in a spray can? It would kinda look like a limited but not at glossy down there. I'm looking for maybe a darker shade of the plastic, mostly to make it look at least nice again and not chaulky.
How to Paint Cladding on wj fizzer WJ Grand Cherokee Forum 12 04-11-2013 06:59 PM
Laredo cladding paint tfgnt16 ZJ Grand Cherokee Forum 2 12-13-2008 04:19 PM
cladding and touch up paint BLACKzj52 ZJ Grand Cherokee Forum 10 09-11-2007 09:35 PM
Laredo Cladding Color Code speedfreak04 ZJ Grand Cherokee Forum 13 10-27-2006 10:17 AM
paint prepping the cladding evans1010 ZJ Grand Cherokee Forum 5 07-11-2006 05:48 PM
