What can be done for less as possible - JeepForum.com
post #1 of 11 Old 06-06-2011, 02:31 PM Thread Starter
DayneZ
Wanna start making the jeep look sick, but dont have the money to do all i want right now. Where can i start to get on my way? I already figured cutting the bumpers and adding a roof rack. Maybe smoking tailights and headlights? And i thought about moving the antennae to the side below the taillight. Let me know what you think...open to all suggestions!!
DayneZ is offline
post #2 of 11 Old 06-06-2011, 02:41 PM
phbrown
1994 ZJ
stickers?
1994 Jeep Grand Cherokee Laredo| stock| 231 transfer case| 4.0L
phbrown is offline
post #3 of 11 Old 06-06-2011, 02:43 PM Thread Starter
DayneZ
got my zoom bait, strike king lures, backwater paddels, quantum stickers on there...im a big fisherman. Also got the daystar stickers and oakley decals
DayneZ is offline
post #4 of 11 Old 06-06-2011, 03:28 PM
Midnightluckey
You could paint stuff? Put a BB in? Do you already have a CB?
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #5 of 11 Old 06-06-2011, 04:02 PM
LordHobbit
go drive through a big mud puddle.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 11 Old 06-06-2011, 04:25 PM
cdaniels85
x2!
cdaniels85 is offline
post #7 of 11 Old 06-06-2011, 05:43 PM
biebs53
Lower it with some 22's and add as much chrome as possible
1998 Jeep Grand Cherokee 5.9 Limited
Build thread:
biebs53 is offline
post #8 of 11 Old 06-06-2011, 05:55 PM
rooster51
24's are the new 22's.
Terry
rooster51 is offline
post #9 of 11 Old 06-06-2011, 06:02 PM
biebs53
I meant 22" tires to go with his Inline V6
Build thread:
biebs53 is offline
post #10 of 11 Old 06-06-2011, 06:25 PM
TallyZJ
Start slow and use your budget. Focus on something you want to do first and just simply collect some money up as you are able and then find that particular thing and get it as cheaply as possible. You will find that getting in a hurry will lead to buying inferior parts that you will not be happy with.
I am on my third or fourth year of running my 1996 ZJ Laredo, and just this past winter I finally got the lift springs under it. I actually purchased the lift kit used, which included front and rear Rubicon Express coil springs and two Rubicon Express adjustable track bars off of a forum member. I stored this kit for nearly two years before I was able to get it installed due to lack of other parts.
I traded some stuff for some good used Rubicon Express twin tube shocks for my lift height. Held those for almost two years before I put them on while waiting to lift it.
Then I got two upper front control arms. Then I got two lower front control arms. I then installed that set. I still have factory rear arms.
I then purchased an IRO adjustable heavy duty track bar for the front. That is now installed.
I got JKS upper shock stem eliminators and lower bar pin eliminators. I just installed those last week. Had them for months.
Last December I purchased a set of Maxxis Big Horn Radials 265/75/R16.
Coming together but slowly.
You really should do your lift and tires first. Everything else you buy might be based off the amount of lift you go with.
Make a plan:
- Decide what tire size you want to run
- Plan how much lift you need for the tire size you plan to run. Then start collecting the parts for your lift. Try to get good used stuff.
- Don't cut anything until you find out what you need to cut
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #11 of 11 Old 06-07-2011, 06:01 AM Thread Starter
DayneZ
Thanks tallyZJ that was helpful....as far as the 22s and 24s and chrome and all that...you can have that, i'll stick with mud and rock
DayneZ is offline
