What brand and weight of motor oil for a 95 Grand Cherokee? - JeepForum.com
post #1 of 8 Old 11-25-2006, 07:20 PM Thread Starter
Keith1975
What brand and weight of motor oil would you guys recommend for a 95 Grand Cherokee?
Keith1975 is offline
post #2 of 8 Old 11-25-2006, 07:57 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
5W30 synthetic in winter, 10W30 or 10W40 synthetic in summer. Any name brand but Quaker State. <- Had oil pressure problems after using QS in my 82 J-10.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #3 of 8 Old 11-25-2006, 08:09 PM
driabyor
driabyor's Avatar
1994 ZJ
i use 15 /40 shell rotella t year round in my 94
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 8 Old 11-25-2006, 08:47 PM
donkie
You will get 8,000 different answers to this one, about as many as what type of wax to use Above 0 deg use 10W-30. 5W if it's colder. Use a synthetic if your wallet does not mind...self change it at 5,000 drain intervals it will save money in the long run. Use a NAPA filter!
Personally I've used Mobil 1 syn after 15,000 miles in 9 vehicles now for literally hundreds of thousands of miles. I usually change it myself, Sam's club has pretty good prices on it. Who knows if it provided anything over regular, sent off a sample one time @ 109,000 miles on my 4.0L YJ and they said everything was perfect and I could stretch the drain interval.
My favorite quote from a vehicle owners manual "use of any fluid or additive not suggested in this manual will only increase your total cost of ownership"
If you really want to see some oil opinion wars, check out some diesel forums...those guys go crazy over oil
Recovering Jeepaholic
2007 Wrangler Sahara - SOLD
Geaux Tigers!!!
donkie is offline
post #5 of 8 Old 11-26-2006, 12:01 PM
sgarlic
What you should run is any quality brand name dino or synthetic, with the thinnest possible viscosity that still maintains good hot idle oil pressure.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
post #6 of 8 Old 11-27-2006, 08:43 AM
sastanley
So...what is a good oil pressure at idle??
I just changed the oil in my '93 ZJ from cheap 20w50 to the 15w40 Shell Rotella and 1 quart of Lucas oil stabilizer (that stuff is like honey btw) because I was burning a quart of oil about every 500 miles. I was ready to try anything. It turns out I think this oil burning was mostly caused by the CCV system being clogged, which a fellow forum member helped me fix up last week.
I just drove the thing on a trip to PA this weekend, and although the initial gas mileage check wasn't so good (16mpg), the thing ran beautifully, didn't burn a drop of oil, nor did it smoke out the folks behind me when sitting in traffic backups, which it used to do regularly. When warm and at highway speed (65-70mph) the pressure was ~45 PSI. At idle (stop light after extensive 65 MPH driving) it would drop to 25 PSI or so. Before this oil change, I would see 40 PSI max when warm and 20 PSI at idle when hot. I attribute this change mostly to the thick Lucas oil in there now, but the stuff is $9 quart!
If I'd repaired the CCV system earlier, I probably would have not used the stabilizer..I was trying a few different things at once, which may be skewing my results.
sastanley is offline
post #7 of 8 Old 11-27-2006, 08:45 AM
rdrbssr11
i use standard 10w30, never had a problem.
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #8 of 8 Old 11-27-2006, 11:13 AM
sgarlic
Anything with a first number viscosity of higher than 5 is not necessary at startup on today's engines. 5 covers the same range of temps, and lower, as a 10 does, so it can be used in the same temperatures as 10, but in colder ones as well.
Adequate hot idle oil pressure is ~6psi, however what you're seeing is plenty. If I were you, I'd use Motorcraft synthetic blend 5w-30. It's cheap, always has great oil analysis results, and will keep your engine nice and protected.
sgarlic is offline
94 grand cherokee motor swap ttavenieriii ZJ Grand Cherokee Forum 16 05-11-2009 09:42 PM
motor mounts 00 grand cherokee peepmyjeep00 ZJ Grand Cherokee Forum 0 01-12-2008 08:43 AM
What weight motoroil 92 Grand Cherokee? texasmail1962 ZJ Grand Cherokee Forum 4 08-20-2007 08:41 PM
'00 Grand Cherokee Ltd Blower Motor misterbluegrass ZJ Grand Cherokee Forum 24 12-18-2006 12:47 AM
1997 grand cherokee need help please new motor daves88gt ZJ Grand Cherokee Forum 6 08-27-2006 07:28 PM
