07-30-2012, 05:40 PM
#1
What brand power steering pump ?
Ok im getting $500 tomorrow from a landscaping Job i did, and I REALLY need a new power steering pump.. Mine leaks badly.. and the pully is cracked, and it wobbles.. I've gone through 4 drive belts in 2 years now the wobbly pully just ruins them i guess.. basicly the pully's after like 3 months just start to chirp and chirp then squeel and dont stop.. My new one with only like 3k miles on it is doing it AGAIN... altho im going to return it and tell them hey... this damn belt is bad and I want a new one.. I doubt they will do anything but it has like a 1-2 year warranty on it so what the hell.. I have a new waterpump, new idler pully, the other pully's are fine, put im not too sure about the tensioner i might need a new one too... How good are those tensioners from advance auto ? They dont seem to be spring ones like the stock one is
The ones at autozone and Advance auto parts have terrible reviews where they leak instantly.. I have tried a junkyard one before for $35 but that was a mistake and waste of money..
So yea need a new pump..
2013 6.2 V8 Camaro SS 2300 miles :-)
1998 5.9 V8 Limited Platinum ZJ 141,xxx miles
1998 4.0 I6 Laredo ZJ 200,003 miles Yay !
07-30-2012, 05:47 PM
#2
I kind of went through a similar ordeal except it was with my steering gear... So I ponied up and got a PSC gear and haven't been happier since. That said, I recommend going with a PSC pump. It may be a little more expensive than the others, but you're paying for the quality and peace of mind. Always better to do it right the first time around.
http://www.pscmotorsports.com/97-06-...reservoir.html
It says for 97-06 TJ, but they list it as the same for ZJs. You can cross reference part numbers or give them a call to be sure.
07-30-2012, 05:52 PM
#3
Funny how reviews go,in all my years of selling auto parts i very rarely run into a defective pump
07-30-2012, 08:19 PM
#4
Well I just dunno if i should take the chance with like 10 reviews all 1 star.. lol
As far as the TJ pump, is that really the same pump.. looks like it.
07-30-2012, 09:26 PM
#5
Belief In All Things Jeep
get a metal pulley from an early ZJ
07-30-2012, 11:10 PM
#6
I bought one from Oreilly's a while back. I haven't had any problems with it and it came with a lifetime warranty. And I agree with HighLonesome, get a metal pulley from an early zj.
[URL="http://www.jeepforum.com/forum/f197/vonericsens-build-thread-995145/"]Build Thread[/URL]
Moss Green 95 5.2l zj- 3in lift (2" BB + Upcountry coils), 255 75 R17 BFG M/T on JK Moabs, Durango Airhat, Mopar ECU, Mopar Tire Carrier
07-30-2012, 11:15 PM
#7
They both use the same pump. Pre '03 TJs and ZJs share the same steering gear too. Like I said before, PSC's website lists the TJ pump for the ZJ when you look it up. Also from O'Reilly's website it lists the same pump for the TJ and ZJ. You can check it out under the "compatibility" tab:
http://www.oreillyauto.com/site/c/de...2869&ppt=C0031
I'd go with the PSC pump.
07-30-2012, 11:20 PM
#8
Also if you're looking for a new tensioner, check at Napa. I recently replaced my tensioner last year from Napa and it was exactly like the oem tensioner and was made in Canada. Much better than the Mexico or Chinese junk.
07-31-2012, 05:07 PM
#9
I went with the one from Advance Auto last year for mine. I was also worried about the bad reviews and talked to the guys at the store (lucky to have a few good knowledgeable folks there) who said the rarely get returns on that pump. I also got a metal pulley from them and put it on last Oct. No problems. I think most of the reviews came from people that beat the pulley on with a hammer.
07-31-2012, 06:00 PM
#10
in my 5.2 97 should I use ATF+4 for the fluid ? it's full ps fluid but my fluid always is smoking when I take off the cap even hours after parked if I'm driving
4" Rough Country Series 2 lift kit with steel radials 33x12.5x15 on d windows
iro rear adjustable track bar, carolina driveline u joint front driveshaft
replaced transmission at 162k with a junkyard one that had 102k.
07-31-2012, 06:12 PM
#11
They both work fine. At the shop today, I had a 94 Cherokee come in saying the PS pump was on the way out. I put ATF+4 in it. Fixed all noises. Ran like a new pump.
