What BB should I get??? - JeepForum.com
post #1 of 11 Old 02-21-2012, 10:34 AM Thread Starter
Dluenz
Does anyone have the 2.25" BB from 4wheelcustoms.com? I would rather do that than a 1.75 daystar but if its bad I wont. Same price and more lift so Im hoping Ill get some good feedback. Thanks!
Dluenz is offline
post #2 of 11 Old 02-21-2012, 10:36 AM
PolkaPower
They are all made from poly. They will probably be 2" and the stock coil isolator is .25". I have the daystar and they are fine. The 4wheel customs shouldn't be any different.
PolkaPower is offline
post #3 of 11 Old 02-21-2012, 11:32 AM
BigClay
I remember a thread on some forum about durometer (I think that is what it is called) testing of different BBs, and I believe there was some difference between different manufacturers, but I don't think it was that big of difference to matter. I think you should be fine.
Current: 98 TJ, 33" TSLs
Past: 94 ZJ, built for the rocks
BigClay is offline
post #4 of 11 Old 02-21-2012, 11:42 AM
samsonitesamson
You can get a complete fat bob's kit on ebay for $50
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #5 of 11 Old 02-21-2012, 12:03 PM Thread Starter
Dluenz
Thank you!
Dluenz is offline
post #6 of 11 Old 02-21-2012, 12:48 PM
RTQL8
how is the fat bobs kits? i thought about doing a 3" for now untill i can get a suspension lift i like.
RTQL8 is offline
post #7 of 11 Old 02-21-2012, 12:59 PM
TMNT2210
I have fat bobs on my rig and they are worked well. the front was kinda tight to put on. 2" for all four- $50.00 ((EBAY))
Dereck
If you don't know what a ZJ is- you can't afford it! -Beerfest
"cowabunga!!!" -TMNT
TMNT2210 is offline
post #8 of 11 Old 02-21-2012, 01:02 PM
RTQL8
how do you mean "tight" to put on?
RTQL8 is offline
post #9 of 11 Old 02-21-2012, 01:03 PM
RTQL8
and is that just a BB kit? or suspension kit?
RTQL8 is offline
post #10 of 11 Old 02-21-2012, 01:11 PM
gabrod72
It's a combo... states he has 4" RC and 2" BB. Hopefully long armed and aftermarket trackbars at that height
gabrod72 is offline
post #11 of 11 Old 02-21-2012, 02:34 PM
samsonitesamson
I put the fat bobs kit on last weekend, It's easier to just pull the rear bolt out of the LCA's, and drop everything down to put the front's on, that way you don't need a spring compressor.
I need to order adj. track bars now though, not imperative, but it needs it.
bb , budget boost , lift , zj
