What axles should I consider? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > What axles should I consider?
RIGID LED Light Blowout Sale - All Sizes, All Series, all Magnaflow SS Cat Back Exhaust System, Street, High ClearanJeep Long Arm Upgrade Kits on SALE for as low as $649.95 S
Unread 12-16-2014, 01:21 AM   #1
6x-gpapa
Which axles will give me: 1. Wider track-stock is 58", I'd like about 64-65". 2. strength upgrade-stock is Dana 30/35, I'm thinking in the range of a Ford 8.8 strength-wise. 3. lowest cost possible-purchase price, maintenance and upgrades. This is for my '93 ZJ/5.2L V8, 46RH/242 T-case, 3.5" lift. I don't need Dana 60-GM14-bolt-Ford 9" strength as I use my ZJ in the 'Expedition/Overland/Camping/Mild Trail' mode. I'm also quite conservative in my driving style. So any ideas that would fit the bill? Which junkyard trucks/parts should I be looking for? Any advice will be greatly appreciated. I'll be doing most of the work myself, with welding done by my nephew. Thanks.
6x-gpapa is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 03:24 AM   #2
Timo_90xj
Timo_90xj's Avatar
Stock WMS-WMS is 60" front and rear. It's the 5.25" backspacing that results in the narrowish 58" track width.
I would say if you can do the welding for all the brackets, find a set of JK axles; the "next generation" D30/D44s are stronger than the ones on our Jeeps, JK WMS-WMS is about 65". People run 35s on (non-Rubi) JKs pretty reliably, so they should hold up to your use as well.
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 09:02 AM   #3
OWSIN
Regular Joe
OWSIN's Avatar
You're limited by the driver's side differential of the front axle, which means either scabbing axles from other model Jeeps as Timo said, or if you want to go full-width, that limits you to Dodge/Ford axles for the front.
You can find a front D44 with the driver's side differential in older Ford trucks (pre-1979), and in 1994-2001 Dodge Ram 1500's, these use a center disconnect instead of locking hubs, but they can be found anywhere, and very cheap. For the rear you're pretty much open to anything, but if you want matching wheel bolt patterns front and rear, would probably be best to grab a matching set from a parts truck.
Personally I have Dodge 1/2 tons under mine, it cost 300$ for the matched set of axles out of the truck. Then it cost about another 1000$ in brackets to adapt them to fit the Jeep, and another chunk to rebuilt them with new balljoints, bearings, etc, etc. The axles really are the cheapest part of a swap like this.
If you can find a matched set of D44/9" axles out of an older Ford, that would be your best bet, as there is a lot of aftermarket for the 9", and they are a fairly strong axle, while not being bulky on the level of the D60/14-bolt. Or if you want to be an odd-ball like me, you can run the Ram axles, do the build on the cheap, and just have to deal with the limited aftermarket support.
Feel free to check out my build thread for lots more info on what's required to fit full-width axles into a ZJ.
Instagram: @laterslater
Build Thread: OWSIN's Half-Ton/Full-width ZJ Build
OWSIN is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 12:54 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
Since the 8.8 can be hard to find in full width the 9" is a very good option. I'd not both with the dodge front axles, they're low pinion. Unfortunately that does put you with a very narrow year range for ford HP44's. The grand wagoneer d44 is also a common swap for wider but not full width.
Owsin has it right though. The axles themselves are the cheap part. I got my hp44 housing, 9" housing, and currie built third in the ratio I wanted for $1500 or so, but I'm looking at easily another 2k on that to get them under the jeep.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 12-16-2014, 04:37 PM   #5
riot1987
Professional Wise Guy
riot1987's Avatar
Im doing a waggy44/ F8.8 swap in mine. They are both plenty beefy. It wont give you your desired width though.
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 04:40 PM   #6
riot1987
riot1987's Avatar
There is an actual bracket/truss kit for the 8.8 that makes it a bit easier to swap in. TNT makes a truss kit for the waggy but its absurdly expensive.
Build thread^^
