What is this? - Page 2 - JeepForum.com
post #16 of 26 Old 07-05-2013, 03:20 PM
zj97ltd
Originally Posted by billyblooshoes View Post
yes, my niner has a sunroof. i was thinking it was some kind of drain, just not sure if it is or what it is for. i was thinking maybe it was some kind of breather tube for the fuel tank, but im not sure how much sense that would make.
This would exlain the whole exploding when hit from behind problem...
zj97ltd is offline
post #17 of 26 Old 07-05-2013, 04:39 PM
98ZJOKC
As you can see, you caught the animals on an off-feeding day.
That is what protects the wiring for a trailer hitch wiring harness. It's not supposed to be hanging down. Push it back up until the metal tabs grab hold of it. The bag you speak of is not from the factory - it would have been from a PO.
Inside of the secret panel you found is where a jeep with a trailer two prep package will have the connections to snap in a trailer hitch wiring assembly. That's also where you should keep your spare power steering pulley, your spare serpentine belt, your A/C bypass pulley, your three ton jack stands, three sets of extra clothes (for when you have to crawl underneath the jeep when you're stranded on the side of the road), instructions on how to disable the alarm system because you will forget, a paperclip to hot wire the A/C compressor...what else am I forgetting?
98ZJOKC is offline
post #18 of 26 Old 07-05-2013, 04:46 PM
jeepkid945
My 93 had that bag inside the panel
jeepkid945 is offline
post #19 of 26 Old 07-05-2013, 05:32 PM
Marcos
Sound deadening
Marcos is offline
post #20 of 26 Old 07-05-2013, 06:24 PM
Kingr98
When you pull your inside trim panels to track that tube back up to the sunroof, you will find more little bags of insulation. I think I found three in mine.
Kingr98 is offline
post #21 of 26 Old 07-05-2013, 08:30 PM
zander21510
The bag is indeed factory. I was at a junkyard and thought I found a bag of drugs lol but sure enough the same insulation was in mine.
Seriously, it is a plug in the place of trailer wiring. Its OK if its not there too.
zander21510 is offline
post #22 of 26 Old 07-07-2013, 09:31 PM
Kingr98
Zander,
I am not trying to be argumentative, but here is a picture of the sunroof drain tube in my 98 ZJ. I know it is my drain tube because I fished a weedeater string from the sunroof, down and out of the rubber tube when my drain was clogged. On my Jeep, I would consider this tube very important, otherwise, every time it rains, my cargo section would flood from under the removable door in the OP's second picture.
Kingr98 is offline
post #23 of 26 Old 07-08-2013, 11:08 PM
zander21510
Originally Posted by Kingr98 View Post
Zander,
Oh I didn't mean to be lol I don't dispute it...in non sunroof ZJs its just a plug that's what I meant . I didn't know it was also the place for the sunroof to drain until reading this thread.
post #24 of 26 Old 07-09-2013, 02:19 PM
Kingr98
It's all good. I just didn't want the OP to hack it off and then fill up his cargo area with water every time it rains.
I do think that the other, oval shaped, covered opening in the picture would be an appropriate place for factory trailer harness wiring, but my trailer hitch is aftermarket so I am only guessing.
Kingr98 is offline
post #25 of 26 Old 07-09-2013, 02:48 PM Thread Starter
billyblooshoes
hey guys, yeah i know im the noob here but my niner does have what seems to be factory tow package complete with skid plate, hitch, and the plug for the trailer wiring. im leaning more towards the sunroof drain theory rather than a plug for where the trailer wiring would go, since like i said, i have the tow package.
billyblooshoes is offline
post #26 of 26 Old 07-10-2013, 11:49 AM
Midnightluckey
No, the trailer wiring goes in the rubber plug you'll find between that drain and the bumper cover. It's closer to the bumper cover. Though strangely, my factory hitch wiring goes out the plug on the passenger side.
Passenger side (with harness)
Driver side (plug only)
it's difficult to see, but its the black square rubber plug in the shadowy area.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
