werid sound coming from engine - JeepForum.com
post #1 of 6 Old 02-16-2006, 05:48 PM Thread Starter
grandsteel98
there is constant ting sound coming from my engine when im drive and when im idoling it sound like the sound the car makes when you turn it off and it is cooling down. does anyone what the problem could be? thanks
grandsteel98 is offline
post #2 of 6 Old 02-16-2006, 06:05 PM
360limited
could be detonation what motor do you have?
360limited is offline
post #3 of 6 Old 02-16-2006, 07:17 PM
greasefingers
greasefingers's Avatar
1994 ZJ
What is the frequency of the sound? Is it rpm related or does it happen like every five seconds? Does it happen all of the time or only at idle?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 6 Old 02-16-2006, 07:18 PM
greasefingers
1994 ZJ
oh yea ... what freckin engine do you have ???
Cheers Steve
post #5 of 6 Old 02-17-2006, 11:28 PM Thread Starter
grandsteel98
i have a 4.0L, it happens all the time idoling and driving, i think it is the water pump.
post #6 of 6 Old 02-17-2006, 11:33 PM
BradBurdett
did you pop the hood while in park to see where the noise is comming from...if its acutally the engine because mine makes ticking sounds at idle and its the evap purge solinoid not the engine on my 4.0L
1995 ZJ 4X4
command-trac (NP231) with SYE
K&N FIPK intake
RE 6.5in lift with 33X12.5 BFG MT and no Rear Sway bar
4.56 gears--axle swap soon
BradBurdett is offline
'94 Grand Cherokee chirping sound coming from engine? 81Euro ZJ Grand Cherokee Forum 9 07-31-2010 08:54 AM
My ZJ has a bad 'rattling' sound coming from the rear... athomas08 ZJ Grand Cherokee Forum 1 03-08-2009 12:15 AM
whirling sound coming from front end 2000 wj ZJ Grand Cherokee Forum 15 10-25-2007 08:49 PM
squeaking sound coming from right front wheel? RMF001 ZJ Grand Cherokee Forum 13 09-27-2007 02:17 PM
slight growling sound coming from front end cliff WK Grand Cherokee & XK Commander Forum 3 10-20-2006 09:06 PM
