went to the dunes this weekend - JeepForum.com
post #1 of 10 Old 07-19-2009, 09:36 PM Thread Starter
str8stock4l
Ok so i went to the sand dunes this weekend and have a few questions. I have a 04 GC with a 4 inch lift. Stock gears front and rear with no lockers. Im running 32 inch M/T tires. Everything went smooth put my air pressure at 8psi and traction wasnt an issue.
Here is the problem i am running into. Ill be going up some dunes i have my jeep in 4low with it in 2nd gear. It does this if i have it in first and shift into second as well. When i get to the top of some hills the jeep bogs down so i go to throw it in 1st gear to bring the rmps up and the car will only stay in second. If i leave it in 2nd it does the same thing. My trans will not down shift. It shifts fine on the freeway and everything else but not on the dunes. I do plan on buying a locker for the rear and possibly some bigger gears. What are stock gears on the GC with the QT? I felt like i did everything icould and nothing broke. i had a blast. The only thing is i think my SS is going im gettin some cluncking in the front and got really really bad DW on the way home. First time i have ever felt it in this jeep.
str8stock4l is offline
post #2 of 10 Old 07-19-2009, 10:14 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Death wobble is not caused by a worn SS. It is caused by other worn components on the front end. I would check everything out before ordering a new SS.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 10 Old 07-19-2009, 11:17 PM
Minivan
If it makes you feel any better, my trans doesn't shift down to first either. I don't think any thing is wrong, it is probably just some electronic nanny trying to avoid drivetrain damage due to torque shock load. Have you tried lifting off of the throttle briefly? Or just climb it in first.
Not trying to hijack your thread, but how do you like the DT8000's? I have the 3000's on front right now, but they are way too soft for the dunes.
It's always darkest before dawn... so if your going to steal your neighbors newspaper, that is the time to do so.
Minivan is offline
post #4 of 10 Old 07-20-2009, 10:50 AM Thread Starter
str8stock4l
the 8000s were awsome on the dunes. not too soft not to hard. if you let of at the top you get stuck and i tried that and i was down to my axles.
post #5 of 10 Old 07-20-2009, 12:55 PM
FirefightinWJ
I'm guessing you were at Silver Lake?
I was there back in June, but never felt the need to run 4low (other than to tow out a buddy that had his fuel pump die).
I'm not sure if you have any HP mods to your jeep, but my WJ on 31's did just fine in 4hi. I climbed every hill without a problem. For the most part I kept it in D and 2 while climbing. I do have the basic bolt ons (cat and back, FIPK, and 63MM TB) which definitely helped on the dunes in the upper RPM's.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #6 of 10 Old 07-20-2009, 01:01 PM Thread Starter
str8stock4l
nope all i have done to mine is regular old susp lift and tires. im buyin a locker for the rear tow hooks and maybe even re gearing and going out again next month.
post #7 of 10 Old 07-21-2009, 06:25 PM
586ZJ
I was there once already this year, came home with a bent connecting rod WOO HOO!!! I ran my ZJ in 4 all time the whole time, maybe once or twice in 4lo for ****s and giggles. Not sure about your downshifting issue, as I never really had trouble getting up and over (3.5" IRO F>R, 265/75 16 Cooper Discoverer STT's) and with 5 people in it. I am setting up a weekend with my other buddies for the last weekend in September if you or anyone wants to join!!!!
586ZJ is offline
post #8 of 10 Old 07-21-2009, 08:12 PM Thread Starter
str8stock4l
for sure let me know. were all going again next month
2004 WJ totaled by some dumb driver
2005 LJ Finally hit to many mods to list
post #9 of 10 Old 07-21-2009, 08:47 PM
FirefightinWJ
I won't be back till next year, as it is just way to far to do more than once a summer.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
-Devin
post #10 of 10 Old 07-21-2009, 09:13 PM
586ZJ
at least you get out once a year. srt8 I will keep you posted, I cant go until fall due to funds (new engine, cv shaft, brakes, etc etc etc) and a couple vacations this summer in August. But Ill let you know since I dont get on here very often anymore.
586ZJ is offline
so i blew out my SS this weekend on the dunes str8stock4l ZJ Grand Cherokee Forum 8 07-25-2009 10:43 AM
here are pictures from the dunes this weekend str8stock4l ZJ Grand Cherokee Forum 2 07-20-2009 08:50 PM
Jeep Commander in Saudi Arabia Sand Dunes ahmed255 WK Grand Cherokee & XK Commander Forum 39 05-30-2009 12:40 PM
Pismo Beach/Oceano Dunes Jeep Safari Photos nedsud ZJ Grand Cherokee Forum 3 06-04-2006 11:19 PM
Samoa Dunes/Snow Wheeling Pics MendoXJ ZJ Grand Cherokee Forum 5 01-14-2005 01:06 PM
