Well Guys... - JeepForum.com
post #1 of 17 Old 01-26-2013, 08:36 PM Thread Starter
Scopez
1994 ZJ
Well Guys...
The Jeep family has grown.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #2 of 17 Old 01-26-2013, 08:43 PM Thread Starter
Scopez
1994 ZJ
Scopez is offline
post #3 of 17 Old 01-26-2013, 08:45 PM
GazulaZJ
Good call!
GazulaZJ is offline
post #4 of 17 Old 01-26-2013, 08:57 PM
PolkaPower
What are we looking at? The second pic looks like you are in China.
PolkaPower is offline
post #5 of 17 Old 01-26-2013, 09:04 PM Thread Starter
Scopez
1994 ZJ
Haha, I've tried turning it on my phone and then uploading it. It won't work. I'll have to do it when I get on the computer.
Scopez is offline
post #6 of 17 Old 01-26-2013, 09:08 PM
PolkaPower
So you got a 5.9? Congrats! Now fix the plenum!
post #7 of 17 Old 01-26-2013, 09:19 PM Thread Starter
Scopez
1994 ZJ
Haha. She has 163k miles with a bad VC. Plenum doesn't look terribly bad, but I will fix is soon. Valve covers are leaking alittle.
Scopez is offline
post #8 of 17 Old 01-26-2013, 09:35 PM
PolkaPower
Yea same when I bought mine. I would put the plenum at the top of the list besides addressing the transfer case. It can cause bad o2 sensors, clogged cat, gummed up intake, pinging, pretty big hit in power and mpg, ect. I replaced the valve cover gaskets right after the plenum. If I had to do it again I would do both at the same time and replace all radiator hoses and t stat too. It's just easier. Also while the intake was off I replaced the cap, rotor, and crank position sensor. Much easier to reach.
I was shocked at the power increase after the plenum fix. Mine wasn't leaking bad either just a little tear in the gasket. I replaced it around 134K miles.
post #9 of 17 Old 01-26-2013, 09:44 PM Thread Starter
Scopez
1994 ZJ
Its at the top along with my Ram with the 5.9L.
I need to look more into the swapping tcases. I want to swap in the one that can handle the best beating. Big plans for this niner.
Scopez is offline
post #10 of 17 Old 01-26-2013, 10:03 PM
PolkaPower
Atlas? 231?
post #11 of 17 Old 01-26-2013, 10:03 PM
nickpequignot
Atlas? 231?
I was gonna say an atlas too.
nickpequignot is offline
post #12 of 17 Old 01-26-2013, 10:35 PM
1slo_camaro
jealous!!! i would love to get my hands on a 5.9 even needing work. id love to find a trashed body and all and just pull the driveline from and swap into my 4.0.... keep us updated on her!
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #13 of 17 Old 01-26-2013, 10:52 PM Thread Starter
Scopez
1994 ZJ
Atlas? 231?
Atlas may be a bit overkill. 231 may be the ticket. Its what I have in my Ram.
Will do. First thing is probably the valve cover gaskets, plenum, and whatever else while the intake is pulled.
I'll start a build thread when the fun begins.
Is the mopar performance pcm still available? Its got one of those unless JET chips on it now.
Scopez is offline
post #14 of 17 Old 01-26-2013, 11:00 PM
nickpequignot
I thought I read somewhere that you can do a low buck upgrade on a 231 using parts out of a ram 231 is it the chain that is stronger in the ram model? And you can also upgrade the low gear to a 4:1 ratio.
post #15 of 17 Old 01-26-2013, 11:07 PM Thread Starter
Scopez
1994 ZJ
Believe so, my original chain lasted until 243k miles on my ram. Just replaced it about 4 months ago.
I'm definitely going to look into upgrading the 231. What about transmission upgrades like shift kits, etc?
Axles have already been taking into consideration.
Scopez is offline
