Well crap lol - JeepForum.com
post #1 of 3 Old 06-09-2010, 12:55 PM Thread Starter
kentever
Well crap lol
Ok this morning going to work my jeep ran fine but died right before i turned into the parking lot, it started right back up and everything under the hood looked fine. When I left it started fine and drove like normal. Engine temp. oil pressure and everything normal the whole way home until I was about to take my exit. It started tapping and then died right before I got pulled over and would not start back up. I checked the radiator and the cap was cool enough to take off and my overflow tank is still full. I put some water in and it poured straight out the bottom when I got underneath I notice my drain valve is now missing. So I lost all my water and I guess the engine overheated but going by the guage inside it never even got to normal running temp so i didnt know until it started knocking. I tryed to jump it off just so I could get it the 1/2 block to my house and would not even turn over. I let it cool down and started it, runs horrible but I got it into my driveway now. So obviously I need to fix/replace the radiator but what damage is done to my engine and whats making the noise? There is no water in the oil that I can see and the level is fine and not leaking anything underneath except water. Any thoughts?
2000 Grand Cherokee Limited 4.7 V8
Heater Treater fixed!!
kentever is offline
post #2 of 3 Old 06-09-2010, 12:58 PM
JJAMISON_
2015 JK Wrangler
your engine temp sensor works off of the water temp basically so no water= no temp. I would go change the oil for GP, check the belts, maybe even check all the hoses. running out of water shouldn't make it run that bad unless the computer caught it and the code is in there. ???? i dunno.
JJAMISON_ is offline
post #3 of 3 Old 06-09-2010, 01:10 PM Thread Starter
kentever
Raining now so ill wait till later yeah that makes sence about the temp but my temp didnt drop it was just a little below normal when it died. No lights on the dash ever came on and i just checked there are no codes in it now.
kentever is offline
ah crap...what did i do trailblaze WJ Grand Cherokee Forum 7 03-25-2010 09:42 PM
intake crap. trailblaze ZJ Grand Cherokee Forum 0 02-22-2009 09:12 PM
Oh crap, I think I'm screwed! Shinner ZJ Grand Cherokee Forum 26 08-21-2008 10:15 PM
Done With K&N Crap wjs81866 ZJ Grand Cherokee Forum 13 10-17-2006 05:04 PM
what the crap ?! randyszj94 ZJ Grand Cherokee Forum 20 01-14-2006 02:48 PM
