Welding D44A w/track lock - JeepForum.com
post #1 of 23 Old 08-06-2009, 01:02 PM Thread Starter
rustynail
Has anyone welded their D44A with limited slip with success or would this be insane? I would rather put locker, carrier, and gear money into an 8.8 or D44 w/4.10's
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #2 of 23 Old 08-06-2009, 02:48 PM
bigbluezj94
1994 ZJ
ive been down this road... i never did get around to welding it because i went and got some tons for it but i was going to. everyone that i talked to said it wouldnt b a problem. dont waste youre money with the 44a. weld it if you want but if you are going to get gears, lockers, ect. get a new axle.
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
BigBlue build 3/4 ton axles, LAs, 37s
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline
post #3 of 23 Old 08-06-2009, 02:56 PM
squashman702
1994 ZJ
Open carrier, Aussie, and a truss, and you have yourself a "mini 60."
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #4 of 23 Old 08-07-2009, 02:07 PM
bigbluezj94
1994 ZJ
untill you start spinning bearings. also good luck finding an aussie
post #5 of 23 Old 08-07-2009, 02:58 PM Thread Starter
rustynail
So it's weldable even with a limited slip in there? What should be welded?
- Russ
post #6 of 23 Old 08-07-2009, 03:01 PM
CLNinja
CLNinja's Avatar
lol
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #7 of 23 Old 08-07-2009, 03:11 PM
Max78
1992 XJ Cherokee
Originally Posted by CLNinja View Post
lol
Wow. . . howd that work out for ya.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #8 of 23 Old 08-07-2009, 03:16 PM
BLACKzj52
i just bought an aussie last night
straight from their site.
lol at the pinion welded to the ring
BLACKzj52 is offline
post #9 of 23 Old 08-07-2009, 03:27 PM Thread Starter
rustynail
I think I could buy 3 spare welded D44A's for what it would cost to get an Aussie sent up here.
- Russ
post #10 of 23 Old 08-07-2009, 03:38 PM
bigbluezj94
1994 ZJ
the inside of the carrier looks very similar to an open carrier. you just weld the spider gears to the carrier. ive heard of people laying a couple good tacs and it holding but i would def lay a little more bead than that. lol the aussies for the 44a arent discontinued any more?
post #11 of 23 Old 08-07-2009, 04:03 PM
Max78
1992 XJ Cherokee
Ya they are no longer discontinued.
Max78 is offline
post #12 of 23 Old 08-07-2009, 04:24 PM
bigbluezj94
1994 ZJ
good news for WJ and ZJ owners with the 44a! OP, let us know if you end up welding it or not.
post #13 of 23 Old 08-07-2009, 04:47 PM
Bama_WJ
Bama_WJ's Avatar
Yea, but they just cost an arm and a leg. I'll keep my open 44a until someone decides to do an 8.8 swap and I'll buy theirs.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #14 of 23 Old 08-07-2009, 05:39 PM
bigbluezj94
1994 ZJ
yea 400, then shipping, then an open carrier if you have the LSD in it. time for an axle swap...
post #15 of 23 Old 08-07-2009, 06:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
what he said pretty much takes care of all bearing issues since it nearly totally eliminates tube flex. add in the btf diff cover and it doesn't get any stouter at that weight level.
ratmonkey is offline
D44a Anti Lock Sensor Mounting Bolt? cologc46 ZJ Grand Cherokee Forum 3 11-25-2009 02:19 PM
d44a spork40 ZJ Grand Cherokee Forum 11 02-26-2009 11:55 AM
D44a 97 ZJ Steve ZJ Grand Cherokee Forum 3 11-29-2008 06:49 AM
factory d44a lsd/trac lock BLACKzj52 ZJ Grand Cherokee Forum 0 08-27-2008 02:11 PM
The D44a SAZJ ZJ Grand Cherokee Forum 4 12-29-2006 12:36 PM
