Weird transmission problem. - JeepForum.com
post #1 of 4 Old 06-18-2011, 01:20 PM Thread Starter
1995zj
So today i started to have transmission problems, well at least im assuming its a transmission problem. I started having problems a few months ago when i randomly lost park, I had no other problems with shifting or anything. I checked the linkage to see if maybe it wasn't engaging park, everything seemed fine and it was shifting correctly. I ended up just fixing my parking brake and just left it alone because that was the only thing that seemed wrong with it.
So this morning I get up jump in my jeep to go to work start driving. At first I heard a weird whining coming from under the jeep, it wasnt really loud, I figured it was something dragging on my DS or something like that. So im cruising in OD at about 60mph or so. Then it starts acting funny, it would jump up 250 rpm's or so nothing drastic, it doesn't feel like its shifting in and out of OD because the rpm change isn't that drastic. It keeps doing that revving up and down every couple seconds or so. Also I somehow have park again and the whining has gone away, which is why I have no idea what is going on.
If I turn off OD it drives perfect no problems with the revving or anything if i then turn OD back on it takes a a while to shift back into it and continues the same symptoms. If i drive faster it doesn't rev like it does between 50-60. It seems to cruise fine at 70 no problems. I was thinking maybe it was the torque converter or something, maybe a vacuum leak. I really have no idea. Its just having park again seems really strange.
Thanks in advance, Jason
Platinum 5.9l, K&N FIPK, Kolak 3" exhaust, SCT Tuned, Flowmaster 50 series, Doug thorley headers, E-Cutout, 180 thermostat, Fastman 52mm TB, Ported Kegger, Stillen rotors
1995zj is offline
post #2 of 4 Old 06-19-2011, 06:15 AM Thread Starter
1995zj
anyone?
1995zj is offline
post #3 of 4 Old 06-19-2011, 07:45 AM
ZeeJay1997
I think what you are seeing is the torque converter clutch engaging and disengaging. What normally happens is the TCC engages at 45 MPH and disengages when you touch the brake pedal.
What you're describing lends suspicion to this: http://www.transmissionpartsusa.com/...-00053392c.htm
The no park issue is most likely mechanical wear / adjustment of the linkage.
Before you do anything check the fluid while hot, idling in neutral on level ground. Take the connector off top of the transmission and clean it. It wouldn't hurt to pull the pan and check for big chunks to get a general idea what it's like in there.
ZeeJay1997 is offline
post #4 of 4 Old 06-19-2011, 11:32 AM Thread Starter
1995zj
Thanks zeejay, those are the exactly what it feels like. I have already checked the fluid levels they are ok, and they fluid looks pretty clean. I will try pulling that plug and cleaning it and see if that helps any. Thanks again.
1995zj is offline
Weird transmission problem ApisonS-14 WK Grand Cherokee & XK Commander Forum 7 06-04-2011 07:11 PM
Transmission acting weird on lower speeds speedbird1229 ZJ Grand Cherokee Forum 1 03-17-2008 09:16 AM
Weird OD problem Mustang5ohhh ZJ Grand Cherokee Forum 4 02-24-2008 08:43 PM
'93 zj weird problem grosdeutschland ZJ Grand Cherokee Forum 4 12-29-2007 04:06 PM
Weird CC problem madcabbie ZJ Grand Cherokee Forum 4 07-25-2006 01:09 AM
