weird pop from LF, i can feel it thru the floorboard
| Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
Built and Supercharged 47
I have ZERO idea what it is? do you guys have any ideas? i will take a corner, crank the steering wheel maybe a 1/4 turn and most of the time it pops, sometimes its more noticable than others, but it really seems like a suspension issue, maybe LCA? only happens when i turn, the LCA's have brand new bushings in them, so maybe its the threaded ADJ portion of the LCA? i heard of the track bar mounting holes "rounding out" could this make that noise? Thanks for the help guys..
Built Beater 01 WJ MY BUILD THREAD Swapped, SUPERCHARGED Locked, Lifted and Long Armed. 02 Cummins. It has a smoking problem, And it wont quit. K8 GSXR 1000- Jardine,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, B&N |
#2 |
Headed Out West
Check the TB. Have someone turn the wheel back and forth for ya.
Jeff |
#3 |
that would cause the noise you think? it only really happens when i turn.. so yeah that would make sensem good think i have a JKS one on the way. its 4am here, so i have to wait till noon or so :/
#4 |
Living dead mod
could be anything, get under there and let someone turn it while you listen.
'97 zj 5.2, some stuff, some other suff, and some things that even work sometimes. |
#5 |
it happens when i am going around a corner turning... like actually driving... i dont wanna strap myself to a creeper and take a corner at 15mph while i am hanging onto the drag link lol, it only happens when i am actually driving it, sorry i should had clarified that
#6 |
It could be the track bar at the axle. Mine made the same popping noise, and that's what it ended up being.
DD: 98 ZJ Laredo 5.2, all stock Wheeler/Beater: 93 ZJ Laredo 4.0, AW4, 231 conversion from 249 3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard Colorado Jeep Club Member 242 (4.0L) |
#7 |
Mine does that... sort of a clunk/pop sound out of the front passenger side. It does it when I go from a stop either in forward or reverse. Sometimes turning too. I've had the entire front checked out... my track bar, ball joints, tie rods, and bushings are all new. I don't have sway bars... I have NO idea what it is!!
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio (see details) 89 MR2 MK1.5 - Body done, built 450whp 3sgte, 6 year project so far 89 MR2 SC - 317k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going :) 74 CB360 - Lots of cool cafe stuff :D |
#8 | |
what did you do to fix it?
#9 | |
#10 | |
The other avenue to explore with the popping noise on turns could be a frozen brake caliper or one of the axle shafts (with all the break in mileage you've accumulated) could have settled. Call the "Stealership" and get the exact lengths of your front drive axles and if they're shorter or out of specs, they sell axle shafts that make up for the wear or break-in in the front end. Take this with a grain of salt (the aforementioned of what I stated above), but it may help insofar as also checking all your motor mounts as well. I caught that only once (broken motor mount), but everything I've stated, you can "Rule-Out" very quickly. ~Stillin~ ![]() |
#11 | |
Living dead mod
#12 |
I had a grade 8 washer welded on the bracket to repair the wobbled out hole.
#13 |
its simpler than you think. worn upper track bar balljoint. or the balljoint (at the pitman arm) on the drag link.
2007 Unlimited Sahara |
#14 |
ok i am looking at it today, see what i can find
#15 |
This is often shock to axle contact. Check to see if the lower shock mounts are coming in contact with the axle. Look for worn away paint on the shock loop. Bar pin eliminators would solve this.
Double check the track bar torque and mounting holes, along with all the sway bar link parts. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
