Weird engine sound when cold (spark plugs?) - JeepForum.com
post #1 of 16 Old 04-07-2008, 09:20 AM Thread Starter
speedbird1229
Hey!
Recently I've began to notice that when the Jeep has been stopped overnight or for just a longer period, the engine will sound inside much louder and abnormal when I rev it above idle. I'd compare the sound to an old Volvo diesel car which always sound terrible. My sound goes normal just after a few minutes of driving or today when I had more time, I kept the RPM in neutral gear at about 2000 and suddenly it just switched over to normal sound. The RPM also wanted to swing about +/- 500 units while the sound was bad. RPM stopped swinging with the sound change.
I thought that perhaps one or some of the spark plugs are dirty or on their way out? It seems exactly like after a few minutes the plug cleans itself out or something and starts working properly. I haven't changed the plugs yet, they could be quite old on it.
Thanks!
2006 Jeep Grand Cherokee SRT8 Black, 1997 Chevrolet Suburban C1500 Black, 1985 Chevrolet K5 Blazer 6.2 Diesel, 1979 Chevrolet Corvette 383 Stroker 4-Speed (AFR heads etc, about 500 hp), Ex 1996 Grand Cherokee Limited 5.2 (318) V8
speedbird1229 is offline
post #2 of 16 Old 04-07-2008, 12:46 PM
tbm5690
This happened with my buddy's WJ...I believe it was a cracked manifold but I'll check up on that
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #3 of 16 Old 04-07-2008, 12:57 PM
CMARJEEP
CMARJEEP's Avatar
its the mechanical cooling fan... once you start driving it kicks off. its normal. the thing you want to watch for is when it is always sounds like that even when its warm. when that happens the fan clutch has gone bad. but for a minute or two on a cold morning that is normal. mine does that until i drive a block or two after i leave it out on a cold night.
CMARJEEP is offline
post #4 of 16 Old 04-07-2008, 01:04 PM
tbm5690
I don't think his is hydraulic, though?
tbm5690 is offline
post #5 of 16 Old 04-07-2008, 01:09 PM
CMARJEEP
CMARJEEP's Avatar
i think ZJ's came with mechanical fans. im not 100% sure. but his description sounds exactly like the fan.
CMARJEEP is offline
post #6 of 16 Old 04-07-2008, 01:15 PM
JG_Canuck
Originally Posted by CMARJEEP View Post
i think ZJ's came with hydraulic fans. im not 100% sure. but his description sounds exactly like the fan.
I was thinking exactly the same thing...
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #7 of 16 Old 04-07-2008, 01:32 PM
alexo1us
He discribed as a diesel sound.
but for the record zj did not have hydrolic fans 5.9 had electric the rest were belt driven
08 Overland crd
5.9 Wrecked 12 24 07
My New Love Stolen /07/07
01 Grand limited 4.7V8/QD
SFN Silver on Grey
alexo1us is offline
post #8 of 16 Old 04-07-2008, 01:41 PM
Windowsrookie
It's the fan. Completely normal, the fan clutch is full of fluid that needs to warm up.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #9 of 16 Old 04-07-2008, 03:28 PM
alexo1us
if it is a roar he is talking about then yes the fan
08 Overland crd
SFN Silver on Grey
alexo1us is offline
post #10 of 16 Old 04-08-2008, 12:03 AM Thread Starter
speedbird1229
Thanks for all the answers. Never thought this was the case! Yes it's kinda like a roar, if I have time I will try to record it with video camera just to be sure. So the fan is belt driven I believe but what does the fan clutch exactly do? How does it work?
post #11 of 16 Old 04-08-2008, 12:13 AM
CMARJEEP
CMARJEEP's Avatar
it engages when the jeep comes to an idle to provide more airflow. but as soon as you start accelerating the clutch will disengage and the fan will stop spinning because air is now naturally flowing through the grill so the fan is not needed anymore. when the clutch goes bad it will always be engaged and will always be spinning which is what will give you the roar. or it will not spin at all and will overheat when you come to stops....
CMARJEEP is offline
post #12 of 16 Old 04-10-2008, 09:30 AM Thread Starter
speedbird1229
I see. Thanks, will keep my eyes on it just in case...
post #13 of 16 Old 04-10-2008, 10:02 AM
98ZJ_USMC
I was wondering about the same thing. My 98 does this in the cold. Makes sense.
98 ZJ 5.2 Auto with "one million" miles on it. Camoclad exterior means you never have to wax it! The journey continues......Jeep On, baby!
98ZJ_USMC is offline
post #14 of 16 Old 04-10-2008, 04:30 PM
JKot55
I always wondered that too. Thought it had to do with the transmission but never looked into it. Thanks!!
JKot55 is offline
post #15 of 16 Old 04-11-2008, 12:16 AM Thread Starter
speedbird1229
But if a spark plug went out, how do you notice it on a V8 engine? Does it add vibrations or loose a lot of power?
whistling sound when engine is cold billybaseball ZJ Grand Cherokee Forum 2 01-04-2010 07:51 PM
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 06:17 PM
HELP !!changed spark plugs- Loud clicking from engine, then stalls alecmcmahon ZJ Grand Cherokee Forum 1 10-12-2008 02:06 PM
what engine oil and spark plugs 4.7v8 kiesha WK Grand Cherokee & XK Commander Forum 9 06-25-2008 01:38 PM
check engine light after changing spark plugs Jayhawk077 ZJ Grand Cherokee Forum 18 06-13-2006 08:04 AM
