Weird electrical issues - JeepForum.com
post #1 of 8 Old 09-18-2013, 04:54 PM Thread Starter
Chris_W_2k5
I'm not even sure where to start looking in my heep right now, but here's the situation.
When the jeep is running, if I turn the wheel full left, the interior lights come on and the DIC says the driver side door is open. Same thing happens at various degrees of wheel turn to the right.
It seems to only happen when the jeep is on, so I suspect something around the ignition switch, but other then that I'm lost as to what to even look for. It just started doing this on it's own, no rhyme or reason as to why it started. I didn't do any electrical work on it at all.
'96 stock ZJ
Originally Posted by Crashnburn80
...so assuming your Jeep is right-side-up you should be ok.
Chris_W_2k5 is offline
post #2 of 8 Old 09-18-2013, 06:38 PM
ZeeJay1997
broken wire in drivers door boot.
ZeeJay1997 is offline
post #3 of 8 Old 09-18-2013, 06:41 PM Thread Starter
Chris_W_2k5
Really? The switch works normally and it only messes around when the wheel is turned. Guess it doesn't hurt to look. Thanks
'96 stock ZJ
post #4 of 8 Old 09-20-2013, 01:55 AM Thread Starter
Chris_W_2k5
Anyone else with ideas?
'96 stock ZJ
post #5 of 8 Old 09-20-2013, 06:15 AM
V65Ozzie
I'm confused as to how these switches work. What triggers the interior lights? The switch that you can see(Door post near the latch), or the one on the door lock? Same question as to what triggers the VIC.
Retreat? Hell, we just got here......
V65Ozzie is offline
post #6 of 8 Old 09-20-2013, 10:08 AM
Aceladriver
It's all from the same switch, the one you can see on the body/pillar by the latch.
It reports to the BCM (body control module) and the BCM tells the lights to come on and activates the door open display on the VIC - and it's also what triggers the alarm to go off if the doors are opened while security is on.
The wiring to the latch itself is only for the lock motor.
Just an FYI somewhat related to this: On early ZJs the interior lights vs VIC and security were divided up between the switch we're talking about and another one that the early ZJs had in the door hinge areas - but I can't remember which of those switches did which, LOL.
It seems like a really oddball problem, BUT - is this with the Jeep moving? ...or just running?
If it's while you're driving and actually turning left or right I'd think it might be bad door hinge pins allowing slight movement of the door itself which can trigger the switch if it's bad enough.
If it's just doing it by turning the wheel while you're not moving - then you've got an 'interesting' problem
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline
post #7 of 8 Old 09-22-2013, 06:27 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Clockspring would'nt fit into the picture I would think.
Originally Posted by HighLonesome
coralman is offline
post #8 of 8 Old 09-28-2013, 03:14 PM Thread Starter
Chris_W_2k5
Sorry for the late reply, I managed to track down the issue. Turns out I had to "build up the door" by taping a plastic washer to the door where the switch meets it. It was never an electrical issue to begin with.
'96 stock ZJ
