Weird droning noise - JeepForum.com
post #1 of 13 Old 05-11-2013, 08:16 PM Thread Starter
zander21510
Weird droning noise
So I've started to notice a droning noise that keeps getting more noticeable that's starting to bother me...I first noticed it a few days after I got my AC serviced, but it doesn't matter what setting I put the AC on or off it doesn't affect the droning at all. The only time it changes is with rpms, it changes based on the rpms but doesn't go away. I can't hear it past 40 or so but I think it's because the road and engine noise just drowns it out...when I brake it's pretty quiet and is best heard in idle.
It's hard to hear if you don't drive it all the time and know that there was something different, my girlfriend hears it though. It's like a low WOOOOWWWOOOWWWOOOOOWW that is slightly irregular. I tried recording it but you can't hear it at all.
I checked all my fluids poked around the engine bay but I can't figure out where it's coming from and everything else seems normal. I can only hear it inside with the doors closed, I can barely hear it if I stand just the right place I can hear it standing outside. The best I could narrow it down to is the passenger side engine bay.
The only oddity I just noticed today on the highway (first time on the highway in a while) is that it kicks down more frequently on slight grades than it did before. It just seems more sluggish than normal.
Any ideas? I don't want something to catastrophically fail especially since I'm depending on it to move me back and forth between Houston and Dallas next month. Thanks guys.
zander21510 is offline
post #2 of 13 Old 05-11-2013, 09:35 PM
ZeeJay1997
My first guess would be the fan clutch or drive belt tension. You can check for noises in the accessories at idle by using a screwdriver for a stethoscope.
ZeeJay1997 is offline
post #3 of 13 Old 05-11-2013, 09:47 PM Thread Starter
zander21510
I thought that too but the clutch is fairly new (like less than a year old) and the tension seemed fine...though I wonder if its all tightened properly....I spose ill check
post #4 of 13 Old 05-11-2013, 09:59 PM
JasonStebbins
Very strange. Check your transmission fluid lately? Just trying to narrow it down. Power steering pump, water pump or idler pulley would be my second guess.
Poop
JasonStebbins is offline
post #5 of 13 Old 05-11-2013, 10:03 PM Thread Starter
zander21510
Actually transmission has been overfilled for quite some time now (just figured it out, thought it was leaking but it's just excess fluid coming out of breather hole)...checked it after a 20min highway drive and it had bubbles. Could that be doing it?
post #6 of 13 Old 05-11-2013, 10:09 PM
JasonStebbins
Bubbles happen from time to time, usually from being under or overfilled. As long as it isn't frothy. Might be time for a fluid change.
Poop
post #7 of 13 Old 05-11-2013, 11:11 PM Thread Starter
zander21510
Probably a good plan...though the fluid smells and looks perfect minus the bubbles after longer drives, and the more frequent kickdowns...
post #8 of 13 Old 05-12-2013, 12:22 AM
JasonStebbins
If it looks/smells good then you're probably looking for something else causing the strange noise. My power steering pump started doing something similar on it's way out, but you said it was the passenger side.
Poop
post #9 of 13 Old 05-12-2013, 12:59 AM
phitmein
phitmein's Avatar
Long time Z , and maybe not very related at all .
Are you still running your org. 249 TC or whatever ?
phitmein is offline
post #10 of 13 Old 05-12-2013, 07:02 AM Thread Starter
zander21510
Hey! Still on the original 242, use 4wd occasionally for rain/fun but most of the time its in 2wd, no change in noise when I shift.
post #11 of 13 Old 05-12-2013, 07:07 PM Thread Starter
zander21510
Update, on a cold start the noise isn't there, only after driving about 20 mins on the highway and stopping to idle again could I hear it. Seems far less sluggish today after driving from Dallas to Houston (abt 200 miles)...maybe it was just a bad tank of gas there.
post #12 of 13 Old 05-12-2013, 09:13 PM
phitmein
phitmein's Avatar
Z, the next time you hear it at idle maybe try pulling the belts and see if it goes away .
That will give us a better clue .
phitmein is offline
post #13 of 13 Old 05-12-2013, 10:34 PM
StevieB76
Sounds like an idler pulley bearing. Had the same kind of noise myself. There are 2 idler pulleys below the ac pump. In my case, noise starting after recharging the ac system, which was empty, changed the belt to a non ac belt....no noice, ac pump sounded and felt good so checked the idler the shorter belt wasn't using. It was toast...
StevieB76 is offline
