weird 5.2 problem - JeepForum.com
post #1 of 5 Old 08-14-2013, 10:09 AM Thread Starter
loodi
weird 5.2 problem
happened 4 times since yesterday. driving 40-50mph in a straight line on LPG, suddenly a very short, half a second stuttering occurs, gas needle drops to min and nothing else happens. i try to switch from lpg to gasoline back and forth a few times, it just runs normally on both. no changes at all.
so nothing bad except this weird short hiccup and the needle drops down to 0.
all 4 times it was like this for about 5mins drive and then it just gradually starts to rise again.
any ideas?
loodi is offline
post #2 of 5 Old 08-14-2013, 10:12 AM
zj97ltd
You're running on LP? That's awesome. No idea though, sorry.
zj97ltd is offline
post #3 of 5 Old 08-14-2013, 10:49 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Electrical for sure.
Fuel pump ground or 12v? That would explain the stutter and the gauge dropping.
Verify the fuel pump and ASD relays.
HighLonesome is offline
post #4 of 5 Old 08-14-2013, 10:51 AM Thread Starter
loodi
Asd?
loodi is offline
post #5 of 5 Old 08-14-2013, 12:04 PM
sebian
I am not read up on the LPG conversions, but I thought the LPG and Petrol had different tanks, which would require separate pumps?
As Highlonesome said, it probably is a bad ground somewhere. Do they share a common ground, or power source?
Edit: ASD is the auto shut-down relay. When it goes out, Jeep doesn't start.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
