Water Trapped in Frame - JeepForum.com
post #1 of 6 Old 12-05-2001, 12:21 PM Thread Starter
psimpson
My 96 Grand Cherokee Limited gets water trapped somewhere in the frame which results in the right rear carpet becoming soaked. This happens when driving in severe rain or when driving extensively in high humidity with the A/C on. There are no obviously blocked drain holes in the frame.
Any help would be appreciated.
Peter Simpson
psimpson is offline
post #2 of 6 Old 12-06-2001, 06:02 PM
GrandCherokeeLifer
That sounds like an internal(in the car itself) problem, not an external one like rain getting in. Have you had the heater core checked?
Alex
5.2 V8 no mods.
04 VW Touareg
GrandCherokeeLifer is offline
post #3 of 6 Old 12-10-2001, 06:59 PM
jeepzj81
ok that sounds like AC evaporation is getting into the car - Grand Cherokees are bad about clogging the drain line for the AC and it will soak the entire passenger side floor board. if this problem only occurs with AC on this is what it might be. there is a TSB i can't find the number but it details how to clean the evap line out. the process is drilling a small hole putting a wire down it and then plugging the hole back up. other signs of it being the evap drainage would be a moldy smell in the cabin.
jeepzj81 is offline
post #4 of 6 Old 12-11-2001, 05:17 PM Thread Starter
psimpson
Thanks for the tip. I'll try cleaning out the drain.
psimpson is offline
post #5 of 6 Old 12-16-2001, 01:35 PM
eir198
I have had the same problem with water on the right hand side. Even had the dealer take a look. There are drain holes that get clogged under the wippers. This is what they told me. It is now happening again even after not using the ac. I noticed it was wet after i washed my jeep.
eir198 is offline
post #6 of 6 Old 12-17-2001, 11:33 AM Thread Starter
psimpson
There is a TSB for this problem, # 960628. The fix is really easy. It took me approx. 5 minutes. Waiting for some warm humid weather to prove the fix is good, but so far so good.
Thanks all. psimpson@auspex.com
psimpson is offline
pulled carpet..need drying ideas..water trapped under plastic. platinum5.9 ZJ Grand Cherokee Forum 42 09-13-2014 05:32 AM
Thermostat Replacement & Trapped Air greasefingers ZJ Grand Cherokee Forum 3 03-10-2006 08:10 AM
WJ frame changes ??? wvresq ZJ Grand Cherokee Forum 2 09-19-2005 04:06 PM
The trapped Duck in my brake line super dave ZJ Grand Cherokee Forum 9 02-18-2005 06:05 PM
water coming in a wj doors when going through water off road mikkjroverland WJ Grand Cherokee Forum 1 10-05-2003 08:04 PM
