water sound in HVAC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > water sound in HVAC
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-14-2009, 09:28 PM   #1
DrEvil
water sound in HVAC
I didn a search but didn't find anything...
When I accellerate from a stop in my 2003 Grand Chrokee Limited, I hear a sound like water swishing around. It comes from under the dash on the pass side. Any ideas?
2003 Jeep Grand Cherokee Limited
2006 Volkswagen Passat 2.0T
1969 Oldsmobile 442
DrEvil is offline   Reply With Quote
Unread 05-14-2009, 09:57 PM   #2
sandman
seriously a search didnt bring up anyhting?
http://www.jeepforum.com/forum/searc...archid=4874249
discussed days ago
http://www.jeepforum.com/forum/showt...+noise+in+dash
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Unread 05-16-2009, 06:07 PM   #3
DrEvil
Originally Posted by sandman View Post
I'm not Bill Gates, but I did a search (as I've done on other topics in the past) and got no results. Your first link above doesn't work and the second link is not related to my issue. Thanks for the FAIL!
1969 Oldsmobile 442
Unread 05-16-2009, 06:14 PM   #4
iluvtruenos
Are you ****ing kidding me?
"and noticed what sounded like water gurgling behind the dash. "
Read the ****ing thread first.
iluvtruenos is offline   Reply With Quote
Unread 05-16-2009, 06:15 PM   #5
iluvtruenos
Oh, and bleed your coolant, that should get rid of the swishing noise.
Unread 05-16-2009, 06:23 PM   #6
indianajeep
indianajeep's Avatar
2005 WK
My 5.2 did this off and on in the winter time after I had replaced the engine. I burped the system once, just to get the major air out, and after that, I let the engine work it out by itself. It does not make that sound anymore. Do you smell antifreeze inside the cabin? If you do, then the heater core might have a leak. Also check the engine bay for any small antifreeze leaks. A leak will let air into the system and cause the sound of the rushing water behind the dash. Usually, air has been introduced into the system for this noise to start in the first place. The air could come in because there is a leak, or perhaps someone took off the radiator cap and let air into the radiator. The radiator system on these late model jeeps is a closed system, in which replacement fluid is added through the overflow tank.
indianajeep is offline   Reply With Quote
Unread 05-16-2009, 06:26 PM   #7
indianajeep
2005 WK
here's another good thread about this annoyance - http://www.jeepforum.com/forum/f13/gurgling-water-sound-347497/
Unread 05-16-2009, 06:28 PM   #8
cadencedad
Its you drain hose!!
cadencedad is offline   Reply With Quote
Unread 05-16-2009, 07:24 PM   #9
sandman
dont know why the first link didnt work but .........
a quote from your original post "I hear a sound like water swishing around. It comes from under the dash on the pass side"
a quote from the second link i posted, again in the original post "noticed what sounded like water gurgling behind the dash"
sure sounds un-related to me
1993 Jeep ZJ. 4.0
Unread 05-16-2009, 07:35 PM   #10
sandman
heres another thread about it
http://www.jeepforum.com/forum/showt...ing+under+dash
and another
http://www.jeepforum.com/forum/showt...=water+in+dash
and another
and another
and another
and another
and another
and another
and another
yea, i take it you searched.
1993 Jeep ZJ. 4.0
Unread 05-16-2009, 07:40 PM   #11
rooster51
Wow Sandman, you are very thorough, you should apply for moderatorship
rooster51 is offline   Reply With Quote
Unread 05-16-2009, 08:07 PM   #12
sandman
^^ dude all i did was search all of those were on the first 2 pages. this is talked about almost as much as the BB. thanks for the complament though
1993 Jeep ZJ. 4.0
Unread 05-16-2009, 09:57 PM   #13
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
^^^^2x^^^^
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote
Unread 05-16-2009, 10:08 PM   #14
Haleyrz
haha sandman, your funny. I will confirm this since the second link you referred was my post. YES this topic is the exact same issue as mine. I was focussing on the gurgle, but the swishing water noise is directly related to the gurgle. They are caused by the same thing as I learned, air in the cooling system. I must work on bleeding my cooling system, as should you OP.
1998 ZJ Laredo, 4.0L, 2WD "Band Van", Current
1997 XJ, 4.0L, 30x9.50 Maxxis Bighorns, super 44, Sold
2003 WJ Overland, 4.7L HO V8, 6000K HID's, Sold
1996 ZJ Laredo, 5.2L V8, 3" Kolak exhaust, K&N FIPK, 4300K HID's, Sold
http://www.facebook.com/home.php#/pr...27&ref=profile
Haleyrz is offline   Reply With Quote
Unread 05-17-2009, 03:53 PM   #15
DrEvil
Wow. When did this forum get filled up with d-bags? For the record gurgling and swooshing are 2 different sounds. I don't have gurgling, I have swishing. Why would anyone get so upset that I tried a search and didn't find what I was looking for. I mean really, it impacts your day that much that you have to do multiple searches and rub it in my face. I hope someday I can have as much free time on my hands as you guys. I've had Jeeps for the past 6 years and have always found this forum friendly and useful. Sorry I'm not a Jeep god or a master of searching.
1969 Oldsmobile 442
