Water in rear compartment only. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Water in rear compartment only.
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 06-02-2006, 01:00 PM   #1
vendsit
I have a 96 Grand Cherokee and I'm getting standing water in the rear passenger compartment. I had the a/c actuator motor replaced last week and they checked the drain tube and tell me that's not it. Could it be the drain tubes from the sunroof or the weatherstrip above the door leaking? Has anyone come across this?
Thanks
vendsit is offline   Reply With Quote
Unread 06-02-2006, 01:12 PM   #2
greasefingers
1994 ZJ
My roof rack leaked. The bolts have O-rings on them. I guess the Jerzey acid rain got to them? RTV over each hole fixed mine. It would drip behind the door sill, so I could never see the leak. It just got wet on the rear passenger side floor after a big rain.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 06-02-2006, 01:21 PM   #3
SteelBlue_WJ
SteelBlue_WJ's Avatar
you gotta dump the bong water BEFORE you pass out in the back dude.
I dont smoke btw
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline   Reply With Quote
Unread 06-02-2006, 01:25 PM   #4
vendsit
I just talked to the service manager at the dealership who said it's most likely the drain lines from the sunroof. He also said it's a very expensive fix. Does anyone have the instructions on how to remove the trim pieces?
Unread 06-02-2006, 01:26 PM   #5
greasefingers
1994 ZJ
Stinky stuff … so I’ve been told
Cheers Steve
Unread 06-02-2006, 02:13 PM   #6
GreenDean
Removing the trim is not hard... but its ALOT to type up. I suggest investing in a Factory Service Manual... it will cost less then one hour of labor at the dealer.
GreenDean is offline   Reply With Quote
Unread 06-02-2006, 06:26 PM   #7
greasefingers
1994 ZJ
Use a garden hose to determine if the water is coming from the outside and where it is entering..
Cheers Steve
