Water pump repair pics - JeepForum.com
post #1 of 8 Old 07-14-2013, 02:44 PM Thread Starter
PolkaPower
Pretty straight forward repair. When I took the belt off it started dripping coolant from behind the pulley. I probably would have broken down the next time I drove it. You can see the gunked/burnt coolant on the bottom where it had been leaking.
All my hoses and coolant were new so I reused all. I put a very thin layer coolant safe RTV on each side of the gasket and made sure to get around the bolts.
I did not remove the PWR steering bracket, alternator, or A/C compressor. To get the bypass hose off I loosened the hose clamp and carefully pried it up with a flat head driver and worked around the bottom to unseat it. When I had all the bolts off I wiggled the hose the rest of the way off. For re install I put the hose on first then lined the pump up and held it in place with the torx bolt. Channel locks helped me wiggle the hose back on the rest of the way.
You need to put that torx bolt in the new pump before you install it because the pulley gets in the way.
Removed the E fan.
The one torx bit is a T-50. It's not possible to get a socket on it since it's so close to the pulley.
Cleaned up the mating surface with a razor scraper and some fine grip sand paper then sprayed it off with the hose. Forgot to take pics.
Cleaned all the 7 bolts up, installed, and torqued to 30 ft pounds.
Lubed up the new O ring and tapped the heater line in. Bolted it down and RTVed around it. The old O ring was basically dry rotted on there and split right off with a little digging.
The crown replacement looks great and is working nicely. Buttoned it all back up and ran it for 15 minutes with the A/C on and the temp held fine.
http://i175.photobucket.com/albums/w...ps6176bfd2.png
PolkaPower is online now
post #2 of 8 Old 07-14-2013, 05:29 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Drinking beer while doing repairs makes me start leaking.
Good write up Polka. A bit more in the mix than my 4.0 looks like, but at least the efan gives a little more space to work doesn't it?
Originally Posted by HighLonesome
coralman is offline
post #3 of 8 Old 07-14-2013, 06:12 PM Thread Starter
PolkaPower
Yea there is vast amounts of room in there with it out.
It felt like a jungle out today. Rained like a mofo yesterday then the sun came out and it got real humid. Between the heat and the beer I kept looking for things that were right in front of me. That beer is 8.5%.
Cleaning all the gasket off and the bolts is what took the longest. I noticed some pitting in the metal too. That's why I used the RTV.
post #4 of 8 Old 07-14-2013, 09:30 PM
StPaul59
How did you know it was going bad, assuming it wasnt leaking?
StPaul59 is offline
post #5 of 8 Old 07-14-2013, 09:46 PM Thread Starter
PolkaPower
I am under the front end a lot just to check stuff out. This time I had just gotten done replacing the steering gear and I noticed a drop of green coolant on the harmonic balancer. I got out the flashlight and mirror and tracked it down to right under the pump pulley. That's when I saw all the evaporated black coolant grime in the first pic. Other than that it didn't give me any other signs.
It can also leak from the timing case cover gasket and I had to make sure it wasn't that or any of the hoses first.
I was very lucky I saw that because I had intended on taking it for a 3.5 hour trip out of town that weekend. That would have sucked!
Here is a pretty good video tutorial on water pump replacement for a dodge magnum. https://www.youtube.com/watch?v=AEvpfwf3fJs
post #6 of 8 Old 07-14-2013, 09:54 PM
riot1987
Drove mine for about 2 weeks with it pouring. Poor choice. Nice write up. Good call on the beer, Happy 12k post sir
Build thread^^
riot1987 is offline
post #7 of 8 Old 07-14-2013, 09:54 PM Thread Starter
PolkaPower
post #8 of 8 Old 07-14-2013, 10:45 PM
davidtownsend
2006 WK
I can't believe it rained that much yesterday. In AZ it would rain for an hour and be done. Not a full day. I hate the humid heat. I have to work on the sound system Tuesday and I'm not looking forward to the humidness. Were did you but the replacement water pump?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
