water pump problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > water pump problems
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 08-24-2005, 01:59 PM   #1
chris74
water pump problems
hey, im stuck. I have a 96 grand cherokee laredo 5.2. Recently the water pump went out, engine was running perfect till this. I replaced ther water pump, thermostat, and coolant temperature sensor. However, engine now runs rough and wants to stall. Also getting code 43 on the check engine light. coolant system seems to be working fine though. Now I also seem to be having electrical system problems, as my battery keeps dying(battey and alternator checked out fine). anybody have any ideas?
chris74 is offline   Reply With Quote
Unread 08-24-2005, 02:26 PM   #2
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Maybe battery cables, they tend to corrode near the terminals. Maybe ground connection? check all the sensors and vacuum hoses in the area where the work was done.
Mil code with check engine light is misfire in cylinder #5, or #6 or #7 or #8. Take it by auto zone and have them put the scan tool on it
Scan tool
code
P0305 Cylinder #5,
P0306 Cylinder #6
P0307 Cylinder #7
P0308 Cylinder #8
Maybe a bad or loose spark plug wire.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links: Kevin (AKA KOR) for ZJ & WJ stuff,
Kolak for performance stuff. I6 performance info at Dino's jeep 4.0 performance site
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline   Reply With Quote
Unread 08-25-2005, 05:23 AM   #3
greasefingers
1994 ZJ
Something is wrong in the ignition circuit. Before checking anything make sure the cables and battery are fine.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
