water pump leaking.. - JeepForum.com
post #1 of 9 Old 07-29-2009, 12:47 PM Thread Starter
npray
the water pump on my GC 4.0 L decided to take a poop today and leak all over the place... how hard is it to replace ? I'm in a bind and can't afford to bring it to a shop..
npray is offline
post #2 of 9 Old 07-29-2009, 01:21 PM
elmer_fud
It isn't to hard. I think when I did it on a 4.0 zj I removed the fan then removed and replaced the pump.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 9 Old 07-30-2009, 06:17 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I cut my fan shroud, just enough, to gain better access
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 9 Old 07-30-2009, 10:46 AM
donha1mn
It's not hard at all, two hours of work tops. Just make sure you remove all of the old seal before putting the new stuff on.
5.9 ZJ with some stuff
RIP TROY
RIP RATMONKEY
donha1mn is offline
post #5 of 9 Old 07-30-2009, 04:41 PM
footinmouth47
footinmouth47's Avatar
how hard is it on the 5.2 v8? mine did the same thing and now I have been filling it every few days.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #6 of 9 Old 07-30-2009, 05:02 PM
MAUSS
The water pump on my '93 ZJ 4.0L started leaking two weeks ago... I bought a new pump, but then I sprained my ankle and I haven't gotten back to it. Fortunately I have a lot of other things to drive. You need to get the fan and the shroud loose and remove them together. I like to slide a piece of cardboard between the shroud and the radiator first, just so that I don't accidentally put a hole in the radiator or bend too many fins with the fan (been there, done that).
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #7 of 9 Old 07-30-2009, 05:35 PM
fixitfirstime
Ditto Mauss, then I clamped the new pump in a vise by the power steering pump bracket ears and turned the steel pipe for the heater hose in with some mopar teflon thread sealant paste. Line it up next to the valve cover and adjust it by placing the pump in the hole with no gasket. Once its in place where you want it go ahead and put on the gasket and give it a squeeze.
fixitfirstime is offline
post #8 of 9 Old 07-30-2009, 08:54 PM
donha1mn
Greg
I replaced my water pump in my 5.9 about 2 years ago. Its essentially as hard as everybody is saying. Remove fan and shroud, remove a few bolts, disconnect the hose, remove pump and old seal, and then put it back together with the new kit. Like I said before, like 2 hours max depending on your luck
RIP TROY
RIP RATMONKEY
donha1mn is offline
post #9 of 9 Old 08-05-2009, 06:59 AM
footinmouth47
great. thanks donha1mn.
new water pump leaking?? hipollito ZJ Grand Cherokee Forum 1 07-30-2009 10:41 AM
4.0 water pump leaking mtparker75 ZJ Grand Cherokee Forum 11 10-29-2008 10:57 PM
Water pump leaking xjeepn ZJ Grand Cherokee Forum 27 12-31-2007 06:21 PM
97 ZJ water pump leaking onlyone ZJ Grand Cherokee Forum 3 02-19-2006 06:55 PM
New water pump....ITS STILL LEAKING grasp ZJ Grand Cherokee Forum 8 11-10-2005 06:38 PM
