Water pump instal - JeepForum.com
post #1 of 3 Old 07-01-2004, 07:10 AM Thread Starter
smclarke
Water pump instal
It's been a while since I've done a wp and that was on an old F150. Anyone know what I'd be up against on a 2000 GC?
Doesn't look too bad but...
smclarke is offline
post #2 of 3 Old 07-01-2004, 02:23 PM
Jim Moore
I replaced the water pump on my '96 with the 5.2L V-8. The most difficult part was getting the fan bolt off. I ended up driving a large screwdriver between the pulley and the pump housing to hold it in place.
Jim Moore
San Diego, CA
'96 GCL
2004 GCL
Jim Moore is offline
post #3 of 3 Old 07-01-2004, 09:47 PM
hurk76
Just did mine 2 weeks ago. Concur with Jim--hardest part was getting the fan off. I removed the old pump with the fan attached, and set the impeller in a bench-top vice to hold it in place--came off easily. Took about an hour and a half of cursing at the thing to come up with that, though.
One other problem I encountered was getting the pipe to seal properly in the pump. I thought I had it right, but every time the engine heated up, it sprayed coolant out between the pipe and the pump. After reseating 3 or 4 times, it seems to have stopped (knock on wood).
hurk76 is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 06:50 AM
Bad water pump? wickerham ZJ Grand Cherokee Forum 9 12-02-2009 02:55 AM
to instal the T-case skid...or not to instal? that is the question 5.9 ANDY ZJ Grand Cherokee Forum 9 08-14-2007 09:11 PM
Water Pump nmn ZJ Grand Cherokee Forum 16 09-19-2006 01:47 PM
Water Pump sadic1 ZJ Grand Cherokee Forum 5 11-15-2005 04:53 PM
