water pump gasket troubles - JeepForum.com
post #1 of 3 Old 02-24-2008, 05:34 PM Thread Starter
subzero32
I replaced the water pump, thermostat, and gaskets to each about a month ago and now both leak slightly. Used RTV but i think i used to much and didn't let it cure for 24 hours. Anybody have any tips on before i redo it this weekend? Its a 98 Grand Cherokee, inline 6.
subzero32 is offline
post #2 of 3 Old 02-24-2008, 05:52 PM
driabyor
driabyor's Avatar
1994 ZJ
you may have tightened it too tight and / or put together to soon... a light bead is better. Just let it set for a few minutes... I use Indianhead cement on the removable part,as in the water pump.. Regular blue permatex on the gasket where it attaches to the engine.... Usually all the gasket then sticks to the part I remove. Besides you can let the rebuilder worry about scraping gaskets then...
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 3 Old 02-24-2008, 08:07 PM
Vestjam
RTV and a gasket? Pick one, not both.
When I replaced mine, I just made sure the surfaces were clean and then used only the gasket. Torque to specs...
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 06:50 AM
Water pump gasket question jtsjeep99 ZJ Grand Cherokee Forum 4 01-20-2010 05:17 PM
Water Pump Leaking - Can I just change the gasket? cracked ZJ Grand Cherokee Forum 16 10-19-2009 10:22 AM
RTV or Factory Gasket (for water pump) w00t_Masta ZJ Grand Cherokee Forum 11 04-29-2009 04:04 PM
fuel pump gasket 96grandcherokee ZJ Grand Cherokee Forum 14 03-19-2006 12:18 PM
