Water leaks onto driver's side when it rains - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Water leaks onto driver's side when it rains
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 10-01-2004, 11:20 AM   #1
wizjeep97
Hello, I don't know if anyone has experienced this. Everytime it rains, water gets onto the driver's side (under brake pedal), soaking the mats and carpet. This happens only on the driver's side, not passenger. Also, seems to happen only when the car is parked! Any thoughts on how to troubleshoot? THX
wizjeep97 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2004, 08:01 PM   #2
Meerkat
Sounds like a two person job to me.
Have a friend with a garden hose run water over the windshield (bottom edge) while you watch under the dash. If you don't see any drips, have your helper move the hose up the edge of the glass across the top then to the sunroof (if you have one).
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote Quick reply to this message
Unread 10-02-2004, 11:50 AM   #3
driabyor
1994 ZJ
could be a bad door gasket
driabyor is offline   Reply With Quote Quick reply to this message
Unread 10-02-2004, 10:26 PM   #4
BillyTJ
cool when i was looking throught the threads i clicked on this quick. Having the same exact problem. Forums are awsome
2001 TJ SE 4cyl manual
31x10.50 on 15x8 Black steelies
[SIZE=2][COLOR=White][B]WHITE JEEP CLUB [/B][/COLOR][/SIZE]
BillyTJ is offline   Reply With Quote Quick reply to this message
Unread 10-05-2004, 09:07 AM   #5
wizjeep97
I tried what WVD said. I pulled back the rug and had someone look while I sprayed water along the driver's windshield. Then I sprayed around where the door meet the fender and a small amount of water was getting in.
It looks like the best approach is to remove the front driver's door fender.
Thanks all for your suggestions!
Unread 01-04-2012, 04:12 PM   #6
CMEvans79
I have an 06 Grand Cherokee (And I know this thread has been dead for awhile) but I'm having this problem too. Any more updates or assistance to fix this problem?
They say your jeep will eventually earn itself a name... Mine has now done that... ladys and gents, meet "Strife" because lately, that's all its given me.
CMEvans79 is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 08:47 PM   #7
mikedelf
2005 XJ Cherokee
i have a 05 grand cherokee and its leaking like crazy, i saw a youtube video, and it showed me that the sunroof drains are clogged, and at the botthom of the floor is where its being clogged which back up to the pilar, im gonna try it tomorrow
mikedelf is offline   Reply With Quote Quick reply to this message
