Water Leak from AC On Floor- HELP - JeepForum.com
post #1 of 1 Old 09-25-2009, 07:27 AM Thread Starter
roth91
I have a 2001 JGC. My AC Unit under the dash has a lot of condenstation on it when the AC is turned on. It is wet and a few drops get on the rug. Some say to drill a hole but I don't want to do that. I tried blowing air through the AC drain line but nothing seems to work.
I assume it is because there is a lot of gunk in the drain. It leaks water under the car but maybe not all is coming out. Is there an easy way to clean out the mess without taking apart the dash? I thought about removing the blower motor and reaching around... will that work? Any thoughts or suggestions would be greatly appreciated.
roth91 is offline
Water Leak under floor mat selim ZJ Grand Cherokee Forum 27 10-11-2010 10:19 PM
Water Leak in Passenger Floor from A/C Any ideas where the drain is? yrkoverland WK Grand Cherokee & XK Commander Forum 1 08-07-2009 03:39 PM
water in the floor polk74 ZJ Grand Cherokee Forum 1 06-10-2009 09:02 AM
Water on the floor Matt2002 ZJ Grand Cherokee Forum 2 07-03-2008 10:11 PM
Water on pass floor help!!! LaCeS OuT ZJ Grand Cherokee Forum 3 07-30-2007 12:30 PM
