water leak - JeepForum.com
post #1 of 2 Old 07-02-2003, 12:03 PM Thread Starter
ely3rd
water leak
93 jeep grand cherokee laredo
water is leaking into the front right passenger floor, especially when it rains heavy. I have seen that TSB related to the a/c evaporator drain leak. I am certain the water is not coming from there. I recreated the link by spraying water on the front right with the door/window closed. it appears it is coming out of the door into the floor, but I can't figure out how to stop it. the weather stripping at the bottom of the window on the exterior of the driver side door seems a little bent up, possibly allowing more water into the door. But it would surprise me if that is adding enough water to create my problem.
help???
ely3rd is offline
post #2 of 2 Old 07-02-2003, 12:08 PM
spichman510
spichman510's Avatar
All my water from the right side is from the ac evap (just had a thread about that). If you sure that is not the case id check all the weather stripping around each door and compare. whatever it is i think should be fixed soon b/c of all the elec. components in the door.
Spicher
-'98 5.9 Grand Cherokee-
spichman510 is offline
WJ Water leak? pauler ZJ Grand Cherokee Forum 7 06-01-2009 06:01 PM
water leak DoneDeere WK Grand Cherokee & XK Commander Forum 5 02-22-2008 07:53 AM
Water leak help GooseAbuse ZJ Grand Cherokee Forum 3 03-16-2007 04:58 PM
XK Water Leak AlTheKillerr WK Grand Cherokee & XK Commander Forum 2 12-18-2006 05:44 PM
Water Leak 93YJjeep ZJ Grand Cherokee Forum 5 04-17-2006 05:09 PM
