Water on the floor of passenger back seat - JeepForum.com
post #1 of 8 Old 06-17-2003, 01:23 PM Thread Starter
oaknpines
I am wondering if the rear winshield washer hose goes under or by the passenger rear seat?
If so and the hose leaks is broke whats the easy fix.
I have not GOne in water so that isa not it
Any Insight would help
Ralph M Jaggi
oaknpines is offline
post #2 of 8 Old 06-17-2003, 04:35 PM
Camster
Camster's Avatar
maybe it's getting through the weather stripping at the top of the door when it rains and is dripping down to the floor. this has happened to me. i don't know anything about the rear washer fluid hose.
Cameron
Camster is offline
post #3 of 8 Old 06-17-2003, 06:57 PM Thread Starter
oaknpines
Hi There - Thanks for the response
but it hasn't rained since April,
so it has to be something else - not water from the seals
Ralph M Jaggi
post #4 of 8 Old 06-18-2003, 02:06 PM
pozner
Sun Roof?
Do you have a sun roof?
Check out the drain hoses to the rear. That's what I'll need to do on mine after I finish replacing water pump and radiator.
Poz
pozner is offline
post #5 of 8 Old 06-18-2003, 03:07 PM Thread Starter
oaknpines
Great idea - but I have No Sunroof
so we are back to the hose routing ??
Ralph M Jaggi
post #6 of 8 Old 06-19-2003, 10:04 AM
Howler
Your AC drain hole is pluged. It is leaking in the passanger side front but becasue of the padding you will only see it in the rear. You will have to drill a hole un the unit and blow air into it to clear.
Here is a link
http://home.sc.rr.com/janet/TSB/24-06-96.htm
Howler
Sorry also forgot to mention to clean the rail it drains into. If you mud a lot it will plug. Look in the wheel well on the passanger side. In the rail you will see a hole about the size of a quarter. You should see a bolt head in there as well. This is where your drain hole is. Make sure it is clear and make sure the rail is clear as well.
Holwer
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #7 of 8 Old 06-19-2003, 12:58 PM Thread Starter
oaknpines
Yes !!
You go to the head of the class !!
My A/C drain was plugged, the carpet hid it, I drilled it out, cleaned it out, and the flood into the car went out the drain as it should !!
Put a plug in the hole, and we are back in business, after the carpets dry out for the umpteen time
Thanks !! You solved it, as I knew someone could on this forum !!
Ralph M Jaggi
post #8 of 8 Old 06-20-2003, 11:30 AM
Howler
We all learn from experience. LOL That was my first mod. The Drain Mod. LOL
Howler is offline
Water In Passenger Floor Board?? SplitNail ZJ Grand Cherokee Forum 18 12-02-2009 12:48 PM
Got water on your passenger side floor? Funk1974 ZJ Grand Cherokee Forum 9 08-16-2008 09:34 PM
95 ZJ water on passenger side floor Funk1974 ZJ Grand Cherokee Forum 1 08-05-2008 08:25 PM
Water on passenger side floor! pacodelahoya ZJ Grand Cherokee Forum 7 03-30-2008 01:22 PM
water on passenger side floor mudlover1832 ZJ Grand Cherokee Forum 9 08-01-2007 07:10 PM
