Water in the floor board..but driver side? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Water in the floor board..but driver side?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder Brawler MID Front Bumper for JKSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 04-01-2009, 12:00 PM   #1
Inavacuum
Title says it all. I know about the fix for the passenger side but I've never heard of the driver side flooding. The weather stripping looks find and the door is not wet anywhere, neither is the carpet higher up. Just the floor on the driver side.
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline   Reply With Quote
Unread 04-01-2009, 12:10 PM   #2
chris_nm1
Is there a body plug on floor board on that side? You might be missing it or it is not in all the way. I'd check for that first.
98' Grandcherokee Laredo 5.2L bored .30over.
Edelbrock Performer Plus Cam
Custom made cat back
3" Teraflex Lift
Terflex Quick Disconnects
31x10.5x15 BFG A/T KO
chris_nm1 is offline   Reply With Quote
Unread 04-01-2009, 01:28 PM   #3
Inavacuum
negative
bump
KOR XMember/TC Skid
Unread 04-01-2009, 04:45 PM   #4
SBlackfoot
Do you have a factory sunroof?
'98 Grand Cherokee Limited, 5.9L, daily driver.
'98 Grand Cherokee Limited, 5.9L, $650 project.
'93 Grand Voyager wheelchair van, 3.0L, chick magnet.
'90 Trans Am GTA, 5.0L/700R4.
'98 Oldsmobile LSS, 3.8L.
SBlackfoot is offline   Reply With Quote
Unread 04-01-2009, 07:31 PM   #5
Inavacuum
nope. no sunroof
KOR XMember/TC Skid
Unread 04-16-2009, 10:56 AM   #6
CDRFunkmeyer
1994 ZJ
Brake Fluid?
Are you sure that liquid is'nt brake fluid? It it is it'll taste super nasty.
Commander Funkmeyer
___________________
1994 Grand Cherokee Limited 4x4, 5.2L magnum,
2" Lift, K&N Air Intake, rockrails, grillguard, full-rack, driving lights, hitchmount gas can/ spare carrier, Hydrogen Cell
CDRFunkmeyer is offline   Reply With Quote
Unread 04-23-2009, 08:18 PM   #7
316Green
wet floor board driver's side
I have exactly same problem. Started last week. It's water for sure. No sign of where it is coming from and no rain or carwash since before it started. Reaccumulates if I try to soak it up.
316Green is offline   Reply With Quote
Unread 04-23-2009, 09:05 PM   #8
newfieZJ
Jeep collector
newfieZJ's Avatar
could be the door seal
newfieZJ is offline   Reply With Quote
Unread 05-04-2009, 07:10 PM   #9
buhler88
I have the same problem. Would love help
Last year I had flooding in the passenger side and it ended up being the rain water running off the windshield. the small tiny drain that jeep has was clogged with leaves, so they made the drain bigger and cleaned out the leaves. Problem fix. Year later... now I have water in the floorboard. Not up high like I did last year in the passenger, but right where my feet would rest. Has anyone figured out whats going on?
-Stef
buhler88 is offline   Reply With Quote
Unread 05-04-2009, 08:19 PM   #10
daufuskieraised
-Stef
Sorry to hijack. But could you tell me what drain your talking about and where it is. Pictures would be great too. My passenger side floorboard is always wet and I can't figure out why. I had the a/c drain unclogged but that didn't help. I also cleaned leaves out of under the plastic cowl cover between the hood and windsheild, and caulked the the seam on the firewall.
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline   Reply With Quote
Unread 05-04-2009, 09:00 PM   #11
ccmf22
i have this same problem with a sunroof tho
ccmf22 is offline   Reply With Quote
Unread 05-04-2009, 09:13 PM   #12
JrMechanic
Check the seal on top of the door frame, right where it meets the hood area. Mine's coming off and I have water on my floor every time it rains. I've got some silicone sitting in my cup holder but im too damn lazy to fix it
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/n...pdated-685644/
JrMechanic is offline   Reply With Quote
Unread 05-05-2009, 10:56 AM   #13
alivenkickin28
if your door rail seals aren't intact or are dry rotted -- they will pour water in around the doors to the floor -- also check to make sure that the hard plastic seals around the windsheild are there -- it will leak there and down the firewall inside...you could also have a disconnected ac Drain from the evap box that will put the AC water in the floor board -- you may not notice it at first until the insulation soaks it up....another thing could be a crack or hole in the heater hose going into the evap box -- have you checked to see if the water was clear or if it was mixed with antifreeze?
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
[url]http://s221.photobucket.com/albums/dd197/alivenkickin28/[/url]
alivenkickin28 is offline   Reply With Quote
