Water on driver's floor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Water on driver's floor
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 01-30-2013, 06:48 PM   #1
wcf59
So get in my '98 Jeep Grand Cherokee this morning to go to work. I start it and the radio speakers are nothing but static. I turned the radio off and STILL static. I get to work and find my driver's front floorboard filled with water, about a 1/4 inch above the carpet. I've had no problem with water getting in. I've been through car washes, etc with no leaks. It did rain pretty heavy last night though. I got home tonight and figured out the area under the driver's side rear seat was filled with water too and apparently the amp didnt like it. I unplugged it and all is quiet for now.
Where should I look for leaks? The Jeep was parked on a driveway with about a 45 degree incline facing up. I have a sunroof too. Its been through car washes several times and I've had no signs of leakage anywhere.
wcf59 is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 04:43 PM   #2
dusterdude
Heater core?
dusterdude is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 08:17 PM   #3
gearheadnick
If it's the driver's side that's wet, it more than likely isn't the heater core or plugged ac drain line. Those normally cause the whole passenger side to be wet. Your best bet I think is to use a hose on the outside to see what is leaking. Obviously, do this an a day when it's above freezing.
My cylinder head overhaul: http://www.jeepforum.com/forum/f13/cylinder-head-r-r-picture-heavy-1348138/
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline   Reply With Quote Quick reply to this message
Unread 02-01-2013, 03:22 PM   #4
wcf59
Yeah, Im thinking with the angle to driveway is on water overflowed into something that allowed it inside. Is there any kind of drain on the driver's side that could be clogged?
Unread 02-01-2013, 04:15 PM   #5
Cherokee95kid
Did it rain or snow where u are? I had water on my driver side floor the other day due to the snow melting. I think it came in from the lower part of the windshield seal then under my dash and dripped onto the floor. My ac only flooded e passenger and rear floors.
Cherokee95kid is offline   Reply With Quote Quick reply to this message
Unread 02-01-2013, 04:34 PM   #6
wcf59
Yes we had a lot of rain during the evening and overnight. Passenger side is dry and fine.
Unread 02-02-2013, 02:36 PM   #7
MustangFX93
I've got the same problem, luckily for me, winter decided to warm up and rain, then freeze the flowing water to my floor pan. The culprit is my weather stripping for my door, it's torn and there was a little river of ice right down to the floor pan.
MustangFX93 is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 04:42 PM   #8
LouC
2007 WK
On the ZJ there is sealer on the cowl seam a that you can see at the lower corners of the windshield. This seam continues under the black plastic piece that covers the cowl area. This sealer can crack and then you can get water under the carpet on either or both sides. Also the torx bolts that hold the roof rack rails can leak and sometimes need to be resealed. Look up under the instrument panel with a bright LED flashlight, look for dried water stains on the black insulation. Finally the windshield seal can leak too.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 04:48 PM   #9
Cherokee95kid
Yup those are both my problems right now :/. One more thing to the fix it list this summer
Unread 02-02-2013, 05:42 PM   #10
wcf59
I'll have a look see at those when it warms up a bit. No sign of leakage on the headliner so I'm going to count out the roof rack bolts. Thanks!
Unread 02-02-2013, 08:10 PM   #11
LouC
2007 WK
Here's a couple of pix of the cracked sealer that I repaired with marine sealant....
Unread 06-30-2013, 04:20 PM   #12
wcf59
How did you apply the sealer?
