Water In Driver Side Floor - JeepForum.com
post #1 of 11 Old 06-01-2004, 08:58 AM Thread Starter
shelter1
When it rains I'm noticing a small puddle of water in the driver's side floor, I broke out thte ole water hose and can see it dripping down the inner kick panel, I bought it used with a new windshield put in I think its that or comming from the hood/cowl area any one else have this happen???
97 4.0
shelter1 is offline
post #2 of 11 Old 06-01-2004, 11:37 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
97 4.0
From what i've read here and personal experience a wet passenger floor is pretty common. It usually comes from a plugged AC condensate drain. It is tricky to fix. There is another thread in the forum that has a detailed discussion of the problem.
http://www.jeepforum.com/forum/showthread.php?t=85523
Doug
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 11 Old 06-01-2004, 11:54 AM Thread Starter
shelter1
Drivers side not AC related
Thanks for the reply though!
shelter1 is offline
post #4 of 11 Old 12-09-2011, 01:47 PM
nikkilee
Wet Driver's Floo
I too get a wet drivers side (front seat) floor. Only seems to happen after one hell of a storm. Carpet behind pedals not wet. Water is under rubber floor mat. My jeep has been in front end crash. Was repaired at "pro body shop" Cant tell where water comes from.
nikkilee is offline
post #5 of 11 Old 12-09-2011, 01:50 PM
nikkilee
Has nothing to do with windshield. Based on leak with old and now my new windshield
nikkilee is offline
post #6 of 11 Old 12-09-2011, 03:31 PM
KoreaZJ
1994 ZJ
Got a sunroof? Plugged drain tube?
KoreaZJ is offline
post #7 of 11 Old 12-09-2011, 03:40 PM
PolkaPower
Park it under cover.
PolkaPower is offline
post #8 of 11 Old 04-17-2013, 03:23 PM
Eds97ZJ
I have this same problem. I can't find the problem but it sure is a lot of water.. Understand this has nothing to do with the passenger side.
1997 Jeep Grand Cherokee LMTD Loaded 5.2 V8 Q-Trac 4X4
Eds97ZJ is offline
post #9 of 11 Old 04-17-2013, 09:31 PM
rcorn79135
One of the leaks on one of my previous Grands was just this. Took a long piece of string trimmer line and fed it through the drain holes in the sunroof channel, sliding it back and forth, to break up a clogged drain tube where it ran behind the kick panel.
96 4x4 Laredo, 97 4x4 Limited, 97 4x2 Limited
rcorn79135 is offline
post #10 of 11 Old 07-13-2013, 10:41 AM
justpino
Where are the drain tubes located so I can take and clear them out?
This is happening to me too.
justpino is offline
post #11 of 11 Old 07-13-2013, 12:37 PM
rcorn79135
The two front drain tubes are the easiest to get to. Open the sunroof and there is one at either side of the front. I cut off about an 8' length of string trimmer line and used it as a drain snake. Followed it with some warm water and watched the water pour out. Worked like a champ.
Water in the floor board..but driver side? Inavacuum ZJ Grand Cherokee Forum 14 12-29-2014 05:31 PM
95 ZJ water on passenger side floor Funk1974 ZJ Grand Cherokee Forum 1 08-05-2008 09:25 PM
water on passenger side floor mudlover1832 ZJ Grand Cherokee Forum 9 08-01-2007 08:10 PM
Help! Wife's GC leaking rain water into driver floor board Mr. Tarmac ZJ Grand Cherokee Forum 5 08-12-2005 01:35 AM
Water on DRIVER side floorboard asuseth ZJ Grand Cherokee Forum 3 12-06-2003 09:18 PM
