washing the engine bay - JeepForum.com
post #1 of 10 Old 03-31-2013, 02:53 PM Thread Starter
Missyj81
1994 ZJ
Anyone on here wash out their engine bay without screwing up their electrical on their zj
Missyj81 is offline
post #2 of 10 Old 03-31-2013, 03:00 PM
x10radsponge
Yep, just cover your battery terminals, coil, and cap/rotor. They can withstand normal water exposure but hose pressure and especially power washer becomes a water injection into the sensitive stuff. I just used plastic walmart or grocery bags to cover.
x10radsponge is offline
post #3 of 10 Old 03-31-2013, 03:07 PM
xcaliber81
I did also however I only covered my rotor and wires leading to the plugs
xcaliber81 is offline
post #4 of 10 Old 03-31-2013, 04:28 PM
newfieZJ
Do it all the time without issue . I dont hit the distibuter area directly , but everything else is no prob . If your wires are good , you won't have an issue . Good way to test them .
newfieZJ is offline
post #5 of 10 Old 03-31-2013, 09:58 PM
1slo_camaro
i grab a bottle of greased lightning about once a month and dump it into a bottle (the sprayer sucks on the regular bottle) soak the entire engine bay down while i drive to the car wash, get there and spray it down with more greased lightning, and spray the SHIIIIT out of it, not focusing the stream on the dizzy or wires other then that clean her up good, ill see if i can find a pic.
after i get done in the summer time ill let it dry and then spray the engine bay with armorall. gives it a nice clean shine
This is with about 210K miles and this is after about 3 months of not washing it and a few trail trips and crappy weather
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #6 of 10 Old 03-31-2013, 10:22 PM
Myusername1674
Clean bay man!
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #7 of 10 Old 04-01-2013, 05:11 AM
KoreaZJ
1994 ZJ
Been using high-pressure washers under the hood since I bought my ZJ new in 2/94. I don't drill in close to anything sensitive. Never had a problem.
KoreaZJ is offline
post #8 of 10 Old 04-01-2013, 01:44 PM
zjosh93
I use the engine degreaser stuff from the parts store, the citrus one. Spray a couple cans on everything under the hood, trans, axles, everything. Wait a few minutes. Hose it off. I make sure to just mist the dist and wires but everything else gets a jet of water. Never had any problems. Not like an Eagle Talon I had once, same thing but only ran water over the parts, no pressure. Wouldn't start until I blew all the underhood connectors out with compressed air and even then it ran poorly for a couple days.
zjosh93 is offline
post #9 of 10 Old 04-01-2013, 02:29 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Get yourself a toothbrush. Engine degreaser and elbow grease.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline
post #10 of 10 Old 04-01-2013, 02:38 PM
Wigginwilly00
I use Simple Green and buckets of hot water from the kitchen sink... Then I usually start wiping and scrubbing followed by gentle rinse with a hose..248,000 miles and still looks good..
2003 Ford SVT Lightning
2000 Jeep Grand Cherokee Limited 4X4
1997 Jeep Grand Cherokee Laredo
Wigginwilly00 is offline
