Washed engine, now won't start... Ugh - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Washed engine, now won't start... Ugh
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 06-24-2013, 06:00 PM   #1
Dubfire98
Ok so I degreased my 5.2 just now... Covered alternator, battery. What the heck have I done?!
Dubfire98 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 06:05 PM   #2
JBrady5555
I splashed through a big rain puddle coming into a gas station once, water came up over the hood pretty good and really drenched everything. Wouldn't fire back up after I finished fillling up. It was just dead, after a few minutes of sitting and drying out it started back up. Maybe your stuff just needs a good airing out.
JBrady5555 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 06:17 PM   #3
Dubfire98
I hope so. Go figure, try to clean the mud off a jeep and it don't wanna run haha.
Unread 06-24-2013, 06:23 PM   #4
xcaliber81
1994 ZJ
Try drying out your distributor wires.
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 06:25 PM   #5
WhiteOut
WhiteOut's Avatar
You soaked the distributor.
WhiteOut is online now   Reply With Quote Quick reply to this message
Unread 06-24-2013, 06:27 PM   #6
zj97ltd
^^-- my first '97 could take a pressure washer to the cap... the one I have now, not so much --^^
zj97ltd is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 07:30 PM   #7
Dubfire98
Update: after an hour of sitting, and dismantling the distributor, she finally fired right back up. Thanks all!
Unread 06-29-2013, 05:13 PM   #8
HandsOn
Glad it finally started.
If you're ever in a hurry for it to dry (for whatever reason) and don't have compressed air handy (perish the thought!), but do have some WD-40, you can spray the WD ("WD" stands for water displacement after all) in there without causing any trouble. Or causing any damage that I'm aware of.
It's pretty benign stuff to most plastics, metals, wires and electronics, so can be used fairly liberally when needed. But a little can go a long way.
Another helpful item that a lot of people have around the house these days is that "air in a can" stuff for cleaning computers. Dust-Off?
I've even been successful in simply blowing inside the distributor body to get the water out. And on a hot day like today, it'll evaporate on it's own pretty quick!
Remember, if an engine won't start after a cleaning, it's almost always the distributor. Other ignition components can do it too, but on distributor equipped rigs, that's the usual culprit.
If it cranks (starter spinning) then it's not the battery, not the alternator, and not any of the circuits related to them.
On carbureted engines, if it spits and fires and runs for a bit, but continually dies and needs to be restarted, then an excessive amount of water could have gotten into the carb somehow (would have to be uncovered and no filter though) as well as the distributor. But except for copius amounts of water in the fuel, the carb won't cause a true no-start issue either.
Only the distributor and it's associated wiring will usually have that effect when things get wet.
Paul
HandsOn is offline   Reply With Quote Quick reply to this message
Unread 04-09-2015, 11:50 PM   #9
goodman351
I degreased my engine on my 96 Cherokee 4.0 now it won't turn over or anything could my starter have gotten to wet. Would a wet distributer cause it to not turn over
goodman351 is offline   Reply With Quote Quick reply to this message
Unread 04-10-2015, 12:26 AM   #10
xcaliber81
1994 ZJ
Yea
Unread 04-10-2015, 08:23 AM   #11
4LtrZJ
Yep...you found this two year old thread...the answer you seek is in it.
4.0L to Freedom
Crawllin' the Fort Worth Mixmaster
ZJ in rehab: http://bit.ly/1DQjcFB
4LtrZJ is offline   Reply With Quote Quick reply to this message
Unread 04-10-2015, 10:23 AM   #12
rednecktrucker
Mine done the same. It's not the dizzy. It's the ignition clip on the front. Take the wire off going to the dizzy cap and blow out the water.
96 GRAND CHEROKEE 5.2 4X4
2014 RAM 1500 CCSB HEMI 4X2
rednecktrucker is offline   Reply With Quote Quick reply to this message
Unread 06-01-2015, 11:44 AM   #13
lunchfist
Thanks guys... i feel like this post is preparing me for when i wash my engine very soon...
lunchfist is offline   Reply With Quote Quick reply to this message
