Washed engine, now won't start... Ugh - JeepForum.com
post #1 of 13 Old 06-24-2013, 05:00 PM Thread Starter
Dubfire98
Ok so I degreased my 5.2 just now... Covered alternator, battery. What the heck have I done?!
Dubfire98 is offline
post #2 of 13 Old 06-24-2013, 05:05 PM
JBrady5555
I splashed through a big rain puddle coming into a gas station once, water came up over the hood pretty good and really drenched everything. Wouldn't fire back up after I finished fillling up. It was just dead, after a few minutes of sitting and drying out it started back up. Maybe your stuff just needs a good airing out.
JBrady5555 is offline
post #3 of 13 Old 06-24-2013, 05:17 PM Thread Starter
Dubfire98
I hope so. Go figure, try to clean the mud off a jeep and it don't wanna run haha.
post #4 of 13 Old 06-24-2013, 05:23 PM
xcaliber81
Try drying out your distributor wires.
xcaliber81 is offline
post #5 of 13 Old 06-24-2013, 05:25 PM
WhiteOut
WhiteOut's Avatar
You soaked the distributor.
WhiteOut is offline
post #6 of 13 Old 06-24-2013, 05:27 PM
zj97ltd
^^-- my first '97 could take a pressure washer to the cap... the one I have now, not so much --^^
zj97ltd is offline
post #7 of 13 Old 06-24-2013, 06:30 PM Thread Starter
Dubfire98
Update: after an hour of sitting, and dismantling the distributor, she finally fired right back up. Thanks all!
post #8 of 13 Old 06-29-2013, 04:13 PM
HandsOn
Glad it finally started.
If you're ever in a hurry for it to dry (for whatever reason) and don't have compressed air handy (perish the thought!), but do have some WD-40, you can spray the WD ("WD" stands for water displacement after all) in there without causing any trouble. Or causing any damage that I'm aware of.
It's pretty benign stuff to most plastics, metals, wires and electronics, so can be used fairly liberally when needed. But a little can go a long way.
Another helpful item that a lot of people have around the house these days is that "air in a can" stuff for cleaning computers. Dust-Off?
I've even been successful in simply blowing inside the distributor body to get the water out. And on a hot day like today, it'll evaporate on it's own pretty quick!
Remember, if an engine won't start after a cleaning, it's almost always the distributor. Other ignition components can do it too, but on distributor equipped rigs, that's the usual culprit.
If it cranks (starter spinning) then it's not the battery, not the alternator, and not any of the circuits related to them.
On carbureted engines, if it spits and fires and runs for a bit, but continually dies and needs to be restarted, then an excessive amount of water could have gotten into the carb somehow (would have to be uncovered and no filter though) as well as the distributor. But except for copius amounts of water in the fuel, the carb won't cause a true no-start issue either.
Only the distributor and it's associated wiring will usually have that effect when things get wet.
Paul
HandsOn is offline
post #9 of 13 Old 04-09-2015, 10:50 PM
goodman351
I degreased my engine on my 96 Cherokee 4.0 now it won't turn over or anything could my starter have gotten to wet. Would a wet distributer cause it to not turn over
goodman351 is offline
post #10 of 13 Old 04-09-2015, 11:26 PM
xcaliber81
Yea
post #11 of 13 Old 04-10-2015, 07:23 AM
4LtrZJ
Yep...you found this two year old thread...the answer you seek is in it.
4.0L to Freedom
Crawllin' the Fort Worth Mixmaster
ZJ in rehab: http://bit.ly/1DQjcFB
4LtrZJ is offline
post #12 of 13 Old 04-10-2015, 09:23 AM
rednecktrucker
Mine done the same. It's not the dizzy. It's the ignition clip on the front. Take the wire off going to the dizzy cap and blow out the water.
94 GRAND CHEROKEE 4.0 5 SPEED 4X4
2004 CHEVY SILVERADO Z71
rednecktrucker is offline
post #13 of 13 Old 06-01-2015, 10:44 AM
lunchfist
Thanks guys... i feel like this post is preparing me for when i wash my engine very soon...
lunchfist is offline
