wanted: 3" lift control arms lenght - JeepForum.com
post #1 of 20 Old 08-23-2014, 03:55 PM Thread Starter
Geo-Nemesis
Hi guys, I am upgrading with a mate his lifted beaten up ZJ and changing all control arms with heavy duty and proper lenght ones.
But I failed with the search function...
can someone tell me the proper lenghts for a 3" lifted ZJ ?
thank you guys
'02 Black Overland H.O. V8
Geo-Nemesis is offline
post #2 of 20 Old 08-23-2014, 04:12 PM
Technohead
I'd start with stock control arm length for lowers and adjust the uppers to dial in caster on the front and pinion angle on the rear.
-Eric
Technohead is offline
post #3 of 20 Old 08-24-2014, 09:22 AM
RemingtonRifles
Iron rock offroad has them
thank you guys
RemingtonRifles is offline
post #4 of 20 Old 08-24-2014, 01:14 PM Thread Starter
Geo-Nemesis
I only need measurements, we already have jks control arms
post #5 of 20 Old 08-24-2014, 01:17 PM
WhiteOut
WhiteOut's Avatar
Set them to stock length, then dial in pinion and caster. There is no "set" length for arms.
WhiteOut is offline
post #6 of 20 Old 08-24-2014, 05:02 PM
airborndad
so what your saying is that the length of the arms they sell for a 3" lift is the exact same length as a stock arm ???
airborndad is offline
post #7 of 20 Old 08-24-2014, 06:12 PM
PolkaPower
No. Do you even lift bro? Axles rotate forward and backward. That's called castor. Your grocery cart has a lot of it. Look it up.
It's just a starting point.
PolkaPower is online now
post #8 of 20 Old 08-24-2014, 07:56 PM
airborndad
Originally Posted by PolkaPower View Post
No. Do you even life bro? Axles rotate forward and backward. That's called castor. Your grocery cart has a lot of it. Look it up.
Hey polkadot******bag
Reading comprehension and use of words in the right context or spelling depends on your actual level of stupidity seem to trouble you it appears.
WTF does "Do you even life bro" mean ?
The OP asked for a length others commented nicely without insults (WhiteOut, Technohead) commented "stock length" again nicely without insults but didn't give an actual length.
I will guess that the OP wanted to see if what he had was in the ballpark of what he needed
No need to be a Keyboard Cowboy with your moronic immature response.
Do you talk to your wife like that?
BTW I used to build race cars for a living so I know what caster and camber is you presumptuous fool!
Grow up kid
post #9 of 20 Old 08-24-2014, 09:17 PM
kodenz
Hey polkadot******bag Reading comprehension and use of words in the right context or spelling depends on your actual level of stupidity seem to trouble you it appears. WTF does "Do you even life bro" mean ? The OP asked for a length others commented nicely without insults (WhiteOut, Technohead) commented "stock length" again nicely without insults but didn't give an actual length. I will guess that the OP wanted to see if what he had was in the ballpark of what he needed No need to be a Keyboard Cowboy with your moronic immature response. Do you talk to your wife like that? BTW I used to build race cars for a living so I know what caster and camber is you presumptuous fool! Grow up kid
You mad bro?
1. No one cares what you do
2.its the internet "do you even life bro?" Actually makes a lot more sense than other things said here
3. He probably doesn't talk to his wife like that
And last but not least
4. You mad bro?
sent from: somewhere
5.2L 1997 ZJ limited Up-Country+2in BB
kodenz is offline
post #10 of 20 Old 08-24-2014, 09:20 PM
WhiteOut
WhiteOut's Avatar
At their shortest length of adjustment, a lot of the adjustable short arms should be close to stock length. From that point, they adjust out to the longer than stock length you're looking for.
I tried to think back to what I was using when I had the short arms and the only number I can come up with is maybe 16.75" for the lowers. Instead of one solid number, it's a compromise between pinion angle, caster and axle location. You can also get a different lift height from the same kit from Jeep to Jeep.
Just keep in mind that you want the front pinion pointed at the transfer case output as best possible and the rear on the same plane as the rear output. having the rear tires a little close to the front of the wheel well is preferred over centered as the rear travels back and up when flexxed.
WhiteOut is offline
post #11 of 20 Old 08-24-2014, 10:17 PM
airborndad
Thanks WhiteOut
that's probably the type of info the OP was looking for
post #12 of 20 Old 08-24-2014, 10:53 PM
PolkaPower
Grow up kid
Hahaha. Those measurements are just a starting point depending on tire size. Try to relax, the Internet not for everyone. Gunga galunga.
post #13 of 20 Old 08-25-2014, 11:28 AM Thread Starter
Geo-Nemesis
actually I know "how to lift" because I have been wheeling with a WJ since 2010, I just wanted to know a set lenght from where to start with the ZJ.
post #14 of 20 Old 08-25-2014, 02:51 PM
Myusername1674
Grow up kid
Mutha ****ing *** hat
hahah no in all seriousness you do need to calm down a little, he didn't even insult the guy! Plus no one likes you
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #15 of 20 Old 08-25-2014, 04:41 PM
airborndad
My apologies to PolkaPower I overreacted to your smart@ss comment
Kodenz
no not mad
#1 your right I know
#2 still doesn't make sense but again your right makes more sense than other things I have read
#3 I hope not and probably a good guess on your part
#4 no, was annoyed not mad but rereading my post I can see where it looked like it
Myusername1674
Hahaha your right, I like your call it like you see it attitude
I was a MFing @sshat and he didn't insult the OP, read it again though I believe I correctly perceived what he said to me as an insult and I overreacted
Again I apologize to you PolkaPower
Nobody cares what I do for a living but if you knew what I do and that this was my 9th 12 hour shift in a row my mini rant would be more understandable
Sorry to all else for the thread turd
Carry on
