want to swap the front axle from a 1995 jeep cherokee to my 98 zj - JeepForum.com
post #1 of 8 Old 02-18-2013, 07:35 AM Thread Starter
jussta5286
I have a 1998 zj that has a bad front diff. the gears are 3.55. I was told that my jeep has a dana 30. i have a 1995 cherokee sport that has 3.55 gears in it too. My question is would the axle assembly work from my 95 cherokee sport to my 98 zj? Both are inline 6 motors and both are geared 3.55. Any help would be great im lost when it comes to ratios and swaps.
jussta5286 is offline
post #2 of 8 Old 02-18-2013, 07:59 AM
ZJMatt
Yes, it will.
My "How to" write up from when I did mine (ZJ to ZJ), but XJ is the same.
http://www.jeepforum.com/forum/f13/h...embly-1461082/
You may need to swap pinion yokes and get a new driveshaft. Oh, also make sure you follow the person's advice further down in the thread and plug off your brake lines as soon as you disconnect them.
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #3 of 8 Old 02-18-2013, 08:03 AM
dnuccio
the XJ axle is a HPD30, so IIRC you will need a custom driveshaft. but the axle itself will bolt in no problem since the XJ and ZJ share the same front suspension.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 8 Old 02-18-2013, 08:29 AM Thread Starter
jussta5286
So if i took my 95 xj out and put it in my 98 zj i would have to get a custom driveshaft? Could i just change out my diff, ring and pinon gears? I havent taken the cover off and looked at it to see exactly whats wrong, but my guess is that the bearing went band and chewed up the teeth.
post #5 of 8 Old 02-18-2013, 08:34 AM
ZJMatt
May need to. Not 100% sure on that, maybe someone else can chime in, but ZJ's had a few different shaft styles and lengths, maybe one will work? It's not as expensive as it sounds to have your shaft shortened and re-balanced.
You could go that route, but to do it properly you need to know what you're doing as far as setting the gears. I chose to swap my whole assembly rather than deal with that.
ZJMatt is offline
post #6 of 8 Old 02-18-2013, 08:37 AM Thread Starter
jussta5286
thats what id rather do too, im going to go check out one from a 97 zj today. the guy only wants 100 bucks for it and its already out. Is there anything i should look for other than the gear ratio?
post #7 of 8 Old 02-18-2013, 08:44 AM
dnuccio
look if it has the cv style driveshaft or the u joint style. The u joint style is ideal and I would stay away from the cv style if you plan on lifting/ off roading with your jeep
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 8 Old 02-18-2013, 08:50 AM Thread Starter
jussta5286
Thanks alot. ill be sure and check that out when i get there.
axle , axle alternatives , zj
