-   -   want to swap the front axle from a 1995 jeep cherokee to my 98 zj (http://www.jeepforum.com/forum/f13/want-swap-front-axle-1995-jeep-cherokee-my-98-zj-1480679/)
jussta5286 02-18-2013 08:35 AM
I have a 1998 zj that has a bad front diff. the gears are 3.55. I was told that my jeep has a dana 30. i have a 1995 cherokee sport that has 3.55 gears in it too. My question is would the axle assembly work from my 95 cherokee sport to my 98 zj? Both are inline 6 motors and both are geared 3.55. Any help would be great im lost when it comes to ratios and swaps.
ZJMatt 02-18-2013 08:59 AM
Yes, it will.
My "How to" write up from when I did mine (ZJ to ZJ), but XJ is the same.
http://www.jeepforum.com/forum/f13/h...embly-1461082/
You may need to swap pinion yokes and get a new driveshaft. Oh, also make sure you follow the person's advice further down in the thread and plug off your brake lines as soon as you disconnect them.
dnuccio 02-18-2013 09:03 AM
the XJ axle is a HPD30, so IIRC you will need a custom driveshaft. but the axle itself will bolt in no problem since the XJ and ZJ share the same front suspension.
jussta5286 02-18-2013 09:29 AM
So if i took my 95 xj out and put it in my 98 zj i would have to get a custom driveshaft? Could i just change out my diff, ring and pinon gears? I havent taken the cover off and looked at it to see exactly whats wrong, but my guess is that the bearing went band and chewed up the teeth.
ZJMatt 02-18-2013 09:34 AM
May need to. Not 100% sure on that, maybe someone else can chime in, but ZJ's had a few different shaft styles and lengths, maybe one will work? It's not as expensive as it sounds to have your shaft shortened and re-balanced.
You could go that route, but to do it properly you need to know what you're doing as far as setting the gears. I chose to swap my whole assembly rather than deal with that.
jussta5286 02-18-2013 09:37 AM
thats what id rather do too, im going to go check out one from a 97 zj today. the guy only wants 100 bucks for it and its already out. Is there anything i should look for other than the gear ratio?
dnuccio 02-18-2013 09:44 AM
look if it has the cv style driveshaft or the u joint style. The u joint style is ideal and I would stay away from the cv style if you plan on lifting/ off roading with your jeep
jussta5286 02-18-2013 09:50 AM
Thanks alot. ill be sure and check that out when i get there.
The time now is 04:50 PM.
