want to swap ECU's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > want to swap ECU's
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 08-15-2010, 01:14 AM   #1
teenwolf1393
want to swap ECU's
ok so i have the infamous stalling stuttering problem, ivve decided to bite the bullet and replace my ecu. i have an ecu from a previous jeep that i owned, i want to know if i can swap the units.
current jeep with the bad ecu is a 97 GC i6 4x2
old jeep 96 GC i6 4x4
can i use the old ecu on my current jeep, is it a simple matter of getting it flashed or do i need one specifically for a 97 4x2??????
teenwolf1393 is offline   Reply With Quote Quick reply to this message
Unread 08-15-2010, 09:17 AM   #2
JS97ZJ
Have you cleaned out the PCM connector w/ tuner spray and apply dieletric greese yet? Common problem on 96-98 JGC.
JS97ZJ is offline   Reply With Quote Quick reply to this message
Unread 08-15-2010, 11:43 PM   #3
teenwolf1393
from what ive read that is a temprary fix
Unread 08-16-2010, 12:54 PM   #4
sdavisbone
Try this... google "ECM interchange and the last 4 digits of your original computer, with any suffix letters" One of the results should be "Smart Page". It crosses all of the OEM computers to an AC Delco version. However, it should show you interchangeable ones. But usually if all of the features are not identical then certain things will not run the same until you have it flashed at a dealer.
Here are the results for my ECM (98 GC 4.0L) Smart Page
sdavisbone is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 04:25 PM   #5
JS97ZJ
here is the fix if the computer connections are at fault....
http://millerspecialtools.spx.com/Detail.aspx?id=247&gid=15
http://www.radioshack.com/product/index.jsp?productId=2103683
http://www.onlinecomponents.com/buy/...O/3-1447221-3/
There is a min order of $35 that would be 100 pins, I have an order in and should be in at the end of the month.
I'll have some left over if your interested.
Unread 08-24-2010, 12:14 AM   #6
teenwolf1393
which number is the part number on the ecm. there are like 10 different number combos
Unread 08-24-2010, 09:57 AM   #7
sdavisbone
Mine is P56044513AB, all other parts numbers that I've seen for the same year are identical until the last 4 digits and the suffix letters. Hope that helps.
Unread 08-29-2010, 04:03 PM   #8
teenwolf1393
my other ecm is from a 96 it doesnt have the numerical sufiix that the 97+ does
Unread 08-29-2010, 10:25 PM   #9
ratmonkey
R.I.P.
ratmonkey's Avatar
You need all the numbers matching. The letters appear to be firmware revisions.
96 ecu most likely won't work with a 97. They are year specific after 95.
ratmonkey is offline   Reply With Quote Quick reply to this message
ecu , pcm , stalling , swap
