want to lift my jeep CHEAP - JeepForum.com
post #1 of 10 Old 01-15-2014, 06:07 AM Thread Starter
droopy199
Anyone know the cheapest way i can lift my 98 grand cherokee laredo?
droopy199 is offline
post #2 of 10 Old 01-15-2014, 06:09 AM
martymars
What do you consider cheap? Are you installing everything yourself? You're looking at $600 bucks.
martymars is offline
post #3 of 10 Old 01-15-2014, 06:11 AM Thread Starter
droopy199
Im thinking more like machining some parts. Like can i block the suspension?
post #4 of 10 Old 01-15-2014, 06:23 AM
Myusername1674
theres a lot of info already on the web of how to do it. try googleing budget boost zj. only cheap way to get two inches, past that it gets expensive quick
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #5 of 10 Old 01-15-2014, 07:17 AM
WhiteOut
WhiteOut's Avatar
Cheapest is going to be about $200-$300 for 2" poly spacers and new shocks. After that it goes up fast ($500+)
Sent from AutoGuide.com App
WhiteOut is offline
post #6 of 10 Old 01-15-2014, 07:21 AM
Technohead
Lift is for posers. If you want to do something useful then get a locker.
-Eric
Technohead is offline
post #7 of 10 Old 01-15-2014, 08:23 AM
nhcd538
$53 and if you're halfway wrench inclined, about 4 hours of work.
http://www.ebay.com/itm/260920025640...84.m1423.l2649
2" will allow for 31's and that's a good start. Your 31's will cost more than the lift, even if you score a used set - don't forget the actual expense of tires themselves.
I wouldn't put a locker in an old Dana 35, but if you do check out an Aussie lunchbox style locker. That and the 31's will make for a decent everyday rig.
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #8 of 10 Old 01-15-2014, 06:33 PM
ejschultz
ejschultz's Avatar
"Cheap" is a word that should never be used to describe "lift" for a ZJ beyond a budget boost. As stated, anything more than 2" gets pricey if you do it right. And a locker makes way more difference than a lift. I wish I would have locked mine before I lifted it. I probably would have stuck with a budget boost at that point and saved a ton of money. But hey, now I'm up 4" and locked so I guess it's a win-win for me.
ejschultz is offline
post #9 of 10 Old 01-15-2014, 07:48 PM
jeeepguy
jeeepguy's Avatar
Originally Posted by droopy199 View Post
...Like can i block the suspension?
BLock the suspension? Really?
That is plain stupid to do on a leaf sprung rig and impossible to do on a coil sprung rig like a ZJ. It would be a really good idea for you to go learn about suspensions in general before plunging into lifting a ZJ.
Good luck...
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #10 of 10 Old 01-15-2014, 10:50 PM
JohnnyZJ
ur gonna need to buy shocks unless you can machine some the correct length.
swap your front coil springs to the rear. and go get some f150 coils out of an older f150. will be good for 3" lift give or take. maybe 4|". cost you a set of shocks. 25" extended. go check older dodge trucks for that length or jeep wranger JKs; they will be similar length for that lift if you don't wanna go new. drill the trackbar bracket up front over 3/4" of an inch. google it.
yep, you can do it dirt cheap. and it will ride like a bag of smashed *******s and you eventually make you jealous of how well a dump truck handles bumps and drives, but hey, if you park it at the mall people might think it looks cool
07' JKUR rollin on 35s
JohnnyZJ is offline
