wandering - JeepForum.com
post #1 of 7 Old 01-04-2012, 02:38 PM Thread Starter
ZTWITT733J
wandering
I put a iro 3.5 lift on my 93 zj and now the steering wheel wanders and the jeep wanders all over the road what will help this?
ZTWITT733J is offline
post #2 of 7 Old 01-04-2012, 02:40 PM
PolkaPower
A proper alignment most likely. Find a shop that works on lifted trucks.
PolkaPower is online now
post #3 of 7 Old 01-04-2012, 02:52 PM
somebody5788
1994 ZJ
Is there a lot of play in the steering wheel? Mine wanders because I need a new gearbox.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #4 of 7 Old 01-04-2012, 02:56 PM Thread Starter
ZTWITT733J
there isnt alot of play it just wont go straight, it wanders all over
post #5 of 7 Old 01-04-2012, 03:00 PM
PolkaPower
Do you have new track bar? An alignment is needed you didn't mention if you got one after the lift.
post #6 of 7 Old 01-04-2012, 03:21 PM
lateralus3
1994 ZJ
what polkapower said
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #7 of 7 Old 01-04-2012, 03:59 PM
gabrod72
Just to clarify things a bit: When you lifted the vehicle, did you re-align the front wheels or correct the pinion angle on the front axle?
I can think of two immediate reasons to align:
1. The stock ZJ steering is two bars forming a Y (can't remember what they're called right now.) If you did not adjust them after a lift, you will need to since lifting the vehicle will essentially toe in your front tires - which in turn will cause all sorts of odd steering issues.
2. When lifting, the front pinion angle increases. This causes your steering knuckles (what the "y" ties into) to become off camber, and this can also cause all sorts of steering and wobble issues.
gabrod72 is offline
Wandering steering Rovingbar ZJ Grand Cherokee Forum 15 08-31-2011 07:56 PM
VERY excessive wandering only in 2wd 2tone93zj ZJ Grand Cherokee Forum 8 01-31-2010 02:42 AM
Front end is wandering... TTaM ZJ Grand Cherokee Forum 6 11-02-2008 09:14 AM
wandering ZJ keeth1123 ZJ Grand Cherokee Forum 0 01-17-2008 05:09 PM
new and just wandering jimbobin ZJ Grand Cherokee Forum 3 10-30-2002 08:40 PM
