Wagoneer Axle Swap-ZJ Brakes? - JeepForum.com
post #1 of 3 Old 11-19-2013, 12:51 PM Thread Starter
1997jeepZJ
okay i bought a 96 Laredo with a 5.2L thats been rolled, i cut the top off and put a cage in it. has now axles on it.
Im not new to the zj scene, also have a 97 5.2 with 6" and 34s
so I Have a Dana44 and AMC model 20 off a wagoneer i had built. both fully locked, geared with chromoly shafts.
I know grand cherokees are 60" track width
Wagoneer Narrow track is 60" front 44.
Rear is about 58"
now i know, wagoneers have different bolt pattern, not a big deal iv already got beadlocks and iroks for those axles.
and yes i know i need to build brackets and stuff for the control arms, track bar, coils, etc.
iv got everything down except the brakes. never even worked with them other than replacing pads now and then.
so what do i need to do to switch out the brakes and make this jeep stop.
is there a difference in the brake lines? i need new ones anyways. thats all im gonna neew help with.
Thanks
1997jeepZJ is offline
post #2 of 3 Old 11-19-2013, 01:08 PM
OverlandZJ
I'd have posted this on the FSJ forum asking what rear disc swap will work on your Model20.
Biggest issue I see is bolting the caliper brackets to your axle.. then finding a rotor or redrilling the Waggy pattern to them. Brake lines would probably be the easiest part of the swap.
I used FroBot Fab (AgitatedPancake here/pirate) bracket kit to swap an iron 44 into my rig.
OverlandZJ is offline
post #3 of 3 Old 11-19-2013, 01:32 PM
speedbucket
try positing in the waggy/cj section for the brakes, theyll bee more knowledgable. the zj brakeline end of it should be plug and play once the backing plate out is figured out. you can buy a t-block and steel brakelines, hand bender for really cheap at any auto parts store for the plumbing
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
axle swap , brakes , grand cherokee , wagoneer
